subwoofer
wallybama1
wallybama1 Posts: 4
edited May 2002 in Speakers
is it ok to put a subwoofer in a builtin bookcase or shold it not be enclosed? where is best place, rear back frount ect?
Post edited by wallybama1 on
  • Ron-P
    Ron-P Posts: 8,516
    edited May 2002
    NOT inside another inclosure and corner loaded is best, most of the time. Experiment with locations. Room acoustics play a big part in sound, esp. with a subwoofer.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2002
    i bult my sub in i bult a hole in my wall and it stickes into the laundry room and is flush in my ht it sounds good but when i buld my sono sub like ron-p i will change it and sell the velo
  • mantis
    mantis Posts: 17,057
    edited May 2002
    If you put a sub into a built in book case,
    you will have sonic problems.Subs are made to be free standing.Not to mention it will rattle any loose things on that bookshelf.
    The corner is a good place to start.
    If you cut yor room in half from front to back,the sub should live in the front half somewhere.The front soundstage seems to always work the best.
    Dan
  • wallybama1
    wallybama1 Posts: 4
    edited May 2002
    thank you, that makes sence.
  • tony27
    tony27 Posts: 49
    edited May 2002
    joe
    just because your 6 inch subwoofer fits in a builtin bookcase , doesn't mean you should put it there.
