Command Bar - Any way to change alarm volume?
My Echo and Echo Dot can both have the volume for timers and alarms set in the Alexa app, but this option isn't available for the Command Bar. Is there any way to increase the alarm volume, or will this option be added to the app?
Thank you.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,611
    Hello,
    I'll ask for you.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
    Hello,
    This is currently not an option for the Command Bar. We are hoping Amazon will add this feature to 3rd party devices like the Command Bar in the future.
Howdy, Stranger!
