Command Bar - Any way to change alarm volume?
KorbenD
My Echo and Echo Dot can both have the volume for timers and alarms set in the Alexa app, but this option isn't available for the Command Bar. Is there any way to increase the alarm volume, or will this option be added to the app?
Thank you.
Thank you.
Hello,
I'll ask for you. -
Hello,
This is currently not an option for the Command Bar. We are hoping Amazon will add this feature to 3rd party devices like the Command Bar in the future.
