Marantz 2238 receiver rebuild
Ya...spring isn't here yet so I need more to do. My son's Marantz is going to get a recap.
It's mainly just dusty! I don't see much for corrosion anywhere.
Aaron
Enabler Extraordinaire
  • ALL212
    ALL212 Posts: 1,556
    edited March 2018
    She's done and it still works! Nothing major - all caps replaced and rebiased.
    Aaron
    F1nut Posts: 49,804
    edited March 2018
    Looks like there's room in there for a motorized remote controlled volume pot. :*
  • Conradicles
    Conradicles Posts: 6,042
  • ALL212
    ALL212 Posts: 1,556
    edited March 2018
    Damn you, Jesse :o ... I even looked now to see if there was room...NO! Gotta quit before I do screw something up. but thanks for the idea, I think...
    Aaron
    txcoastal1 Posts: 13,132
    You got skills
  • ALL212
    ALL212 Posts: 1,556
    For the wizards out there... Was there a machine that did the wire wrap? That is a seriously secure connection. I had no idea...
    Aaron
    F1nut Posts: 49,804
    ALL212 wrote: »
    You have to remove the current pot and replace with the motorized version. How much space is there between the bottom of the pot and the bottom cover?
    F1nut Posts: 49,804
    ALL212 wrote: »
    Yes
  • Conradicles
    Or sell it to me as is. Seriously.
  • ALL212
    ALL212 Posts: 1,556
    No sale on this one. Belongs to my son.
    But I am watching for one to operate on
    Aaron
  • cortico
    cortico Posts: 587
    Nice project! Marantz are pretty easy to work on. I couldn’t stop noticing the cloth covered wire on the main filters. Are you into guitar amp as well? I used the same type on tweed deluxe build :)
  • [Deleted User]
    [Deleted User] Posts: 7,658
    There are wire wrap unwrapping tools made.
  • ALL212
    ALL212 Posts: 1,556
    cortico wrote: »
    I've got a couple of spools of the stuff. It's got a rubber coating, then cloth. I like it on the bottlehead kits I build. It's a fairly heavy gauge and works well in the PS section. Easy to strip - easy to form...
    Well... that would just take all the fun out of this now wouldn't it! If I make a career out of this that might come in handy. The wire is almost worthless after unwinding it (winding a round wire over a square peg really puts some weak spots in it) so I check length before removal just in case.
    Aaron
  • Kingrat
    Kingrat Posts: 74
    I recapped an old, really pretty old Pioneer receiver for a friend a few years ago. I owed him a favor and it turned out fine, except I saw when I had it opened up that the dial cord was about to go, and I wasn't going to touch it. He had to take it to some old guy up near Ann Arbor to get it replaced. It was a lot of money, but he did it amazingly quickly, my friend watched him do it and said it was like watching a machine.
    Cable atheist: They're just trying to get your money like a TV preacher!
    Vinyl system: I'm long done with the snap, crackle, and pop.
