SDA 1.2TL Interconnect cable help
Hi everyone,
I'm a proud owner of the SDA 1.2TL ... again.
Had a pair years ago, sold them, missed them so much, bought another pair 10+ years later. After all these years, I've still not found any speakers that are better value for money.
I've had lots of speakers which haven been better ... but they've been things like the Genesis 350SE which are mega money.
This new pair of 1.2TL doesn't have the interconnect.
Initially I thought it was a standard 2 pin min, but turns out it's not. It looks the same but much bigger.
I've read you can just use an RCA cable with only the pin. I'll do this if I have to, but wondering if I can get the proper plug.
I've also read the other alternative is to replace the pin blade socket with a Neutrik Speakon connector. While this looks good, probably too time consuming for me at this stage.
Does anyone know if the original 'pin blade' plug is a standard size? If so, can these be bought somewhere?
  • pitdogg2pitdogg2 Posts: 11,110
    edited January 30
    Ends cannot be bought aftermarket any where. The cables come up on eBay once in a while for close to 80-100 dollars.
    You have been given the only 2 choices you really have, unless someone wants to get off one or you would like to wait it out for one to show up on eBay.
  • FestYboyFestYboy Posts: 2,866
    Go Speakon, it's the better option.
  • puundapuunda Posts: 97
    Thanks for the reply guys.
    I was wanting to make sure the sockets were not a standard plug you can buy somewhere, and it looks like it's not.
    For now I'll use the RCA cable method, but going forward I will use the Speakon method.
    Will the speakon socket fit on the current round plastic plate? Or do I need replace it with another plate?
    It will fit in the same location once you take the old out.
    Just to confirm.
    The Neutrik/Speakon looks to have 4 connectors. Do I use all 4 and have 2 pairs connected together? or do I just use 2?
  • F1nutF1nut Posts: 40,491
    Are you making a regular SDA cable or are you getting a Dreadnought?
    I was going to make a normal SDA cable. To replace the one which came with the speakers. Was going to get 2 x Neutrik NL4 sockets and a 5m NL4 cable.
    What is the Dreadnought?
    Dreadnaught allows use of non-common ground, and monoblock amps. There are other benefits as well, but that's it's main job.
    Right. I'm almost positive my amp is a common ground (Onkyo/Integra AVR), so will be using the normal cable. Have ordered 2 x Speakon sockets, a 5m Speakon cable (both 4 poles/wires), and 8 nicer looking binding posts. Will be an interesting project.
    Meanwhile will use a mutilated RCA cable for my SDA effects
    Not so fast. Using a Dreadnought with a common ground amp results in better sound than a regular SDA cable.
    You need to make sure the SpeakOn socket is airtight as not all are. The spec sheets on Neutrik's site have that info.
    I strongly suggest not using an AVR to drive those speakers as you'll never hear what they are capable of.
    So the Dreadnought can be used on both common ground and non commond ground amps? And that it makes it sound better? Why isn't everyone doing this?
    $$$ and getting the proper transformer
    puunda wrote: »
    A whole lot of people already have.
    Reasons others haven't:
    They don't know about it.
    Money
    Ignorance
    Think it has to be the special order 1000VA, when the standard 800VA is fine.
  • GlennDogGlennDog Posts: 1,563
    I've got an OEM pin/blade cable FS . . . PM me if interested
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Definitive Technology BP-2
    DAC North Star Design Supremo
    Source PSA PWT & Oppo 105
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Pre Cary SLP-98 F1
    Center Salk HT2C
    Wires MIT S3.3
    PSA PC AC-12
    BOOM there you go...
    Had a chat with GlennDog, and it looks like the shipping to Australia will be too prohibitive. So back to the original plan of using RCA until I can upgrade to Speakon (parts ordered), and eventually Dreadnought.
  • dpowelldpowell Posts: 2,772
    The dreadnought took my SDA's to a whole new level. Watch the forum for future special group orders of the 1000VA transformer coordinated with toolfan machining the cases at the same time. Until that happens, do all the other recommended mods.
    polkaudio Fully Modded SDA SRS 2.3TL's + Dreadnaught, LSiM706c, 4 X TC265i Rears, SVS PB13 Ultra x 2
    Pass Labs X1, Pioneer Elite SC-67, Sunfire Signature Cinema Grande 400, Oppo BDP-83SE, Sony SCD-C333ES
    I doubt we will ever get the required amount to special order again but gosh it would be nice to get one.
  • ManticoreManticore Posts: 286
    If a special order happens i would be game!!!!!!!
    Denon AVR X4200W
    Parasound HCA 1500A amplifier
    Adcom GFA 555 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    NAD pp 4 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk RTiA 7's
    Polk CSi A6
    Polk RTiA 3's
    Polk SDA 1C's modded
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
    In as well
    I've been searching for the dreadnought but not really found any solid instructions. From what I can tell you can the 800va transformer, but the 1000VA is the better one, but it's not available? I'm assuming this is a special transformer? Does someone have a link to the info or instructions to this?
    Meanwhile I'm using an RCA cable, which is working well.
    I've ordered 2 Speakon connectors and a Speakon cable, as well as some fancy insulated banana terminals. Will put those in when they arrive.
  • monepolkmonepolk Posts: 870
    Sounds like you have 2 maybe 3 people. That's a nice start. Might be time to start a thread.
  • verbverb Posts: 3,668
    In as well
    I’m in!
    Basement: Polk SDA SRS, Micro Seiki MB14 TT, VTL 2.5 Pre, Marantz CD6006 CDP, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Bi-Wire speaker cables
    Office: PC, Cambridge CD transport, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable
    Spare Room: Dayens Ampino Integrated, Auris BluMe, Polk TSi200's
    Living Room: Pioneer SX-N30 Network Receiver, Pioneer PD10AE CD Player, Furman M8-LX Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi Subwoofer
  • audioluvraudioluvr Posts: 463
    edited February 8
    I would have but I just bought the AL -906 so I'm going to put that together this weekend and call it good.
    1. Install it in a shielded enclosure.
    2. Wire it up like this:
    Right Pin = Red/Yellow
    Right Blade (Negative Speaker Terminal) = Black/Orange
    Left Pin = Grey/Brown
    Left Blade (Negative Speaker Terminal) = Blue/Violet
    Of course mine will be far more ghetto than this one...
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    B&K Reference 50 Pre
    B&K M200 Sonata Monoblocks
    Cambridge Audio DVD 99
    Sangean HD FM Tuner
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    verb wrote: »
    In as well
    I’m in!
    With the OP you have 4 and I think the minimum order is 10.
  • Viking64Viking64 Posts: 3,492
    audioluvr wrote: »
    HAHAHAHA That one is mine, now. :)
  • TNTsTunesTNTsTunes Posts: 754
    monepolk wrote: »
    verb wrote: »
    In as well
    I’m in!
    Plus someone needs to talk with Larry about possibly building enclosures too.
    I might be in. I already have a 1kva one from the last group buy but I could use another one for my shop at some point.
    Someone also needs to be designated to collect everyone's money, place the order and ship them out to everyone once they receive the order.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • westmassguywestmassguy Posts: 6,149
    audioluvr wrote: »
    I gotta start collecting royalty fees
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    audioluvr wrote: »
    We have a volunteer for collections!
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    audioluvr wrote: »
    audioluvr wrote: »
    Trust when i say...
    You do not want Tonyb showing up at your door.
Howdy, Stranger!
