Best method of transporting vinyl records?
halo
halo Posts: 5,616
Hello everyone,
For those that have moved and have taken their record collection with them, what are some tips or tricks as to getting them there safely?
Best method of packing them? Packaging them?
And no, I'm not selling them or giving them away before I move. lol.
Thanks in advance!
    mhardy6647 Posts: 33,049
    FWIW, I just used cardboard boxes, mostly of the Home Despot kind. Fill 'em full.
    nooshinjohn Posts: 25,101
    The best thing is to let the records transport you. Just darken the room, grab an adult beverage and let the music flow trough you....
    Oh, you meant move them to another location. I get it now. I used a double walled box that was the same dimension as the record themselves and filled the box to capacity so there was no movement or shifting about.
    How many to you have to sell? I mean move... :DB)
  • dromunds
    dromunds Posts: 9,984
    You can get some wooden LP boxes/crates if you're worried about anything. Depends on how many you have and how you value them. If highly collectable, etc. I've seen guys use LP hardcases. (That's what I'd use for my 1st pressing sealed Wildflowers, etc.) Definitely fill whatever box you use to capacity as stated above so no movement or shifting.
  • halo
    halo Posts: 5,616
    Thanks for the input folks!
    I don't need anything super indestructible, I just want to make sure the bottom isn't going to fall out of the cardboard box from the weight of the records. The double walled boxes at H.D. sounds like a good idea. I have ~ 70 records now? Some are not in that great of condition. Others are new or limited editions. So I'd like to try and see if I can get them all there safely.
    Dollar for dollar the Home Despot boxes cannot be beaten -- that was feedback from one of my daughter's long-time friends, who has a moving company as kind of a side business (he's a tech guy of some sort). The heavy-duty boxes from HD are.... pretty heavy duty.
  • Emlyn
    Emlyn Posts: 4,373
    These are tough and good enough for long term storage if necessary. I bought some for my last move a few years ago.
    https://www.sleevecityusa.com/ultimate-lp-storage-box-p/3strlpbox.htm
  • MrBuhl
    MrBuhl Posts: 2,419
    Not inexpensive or of the highest quality, but when I came out here to LA I brought about 200 LP's with me, I bought the LP crates from Container Store, the bigger concern is making sure they don't overheat in transit. Plus side is that these have handles, stack and are easy to carry (because of handles)
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • decal
    decal Posts: 3,205
    Emlyn wrote: »
    I second this motion. I have about 30 of these I used to transport my LPs to the new house. They are real sturdy.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2018
    I just moved our record collection using over 50 boxes from U-Haul they were just right, but I got wore out lifting them completely full so I had to take 70% of the records out of each box near the end. Just about killed me. I could use them over for a couple of times.
    msg Posts: 9,464
    I also have some of the Sleeve City boxes. Perfect fit. If possible, and you're driving, I'd maybe consider bringing them with you instead of in a moving truck?
    Another idea would be the Container Store's "record crates". They're a little flimsy compared to real milk crates, and they're open, but they'd get the job done, though wouldn't protect against dirt/dust.
    The Sleeve City ones fold like a bankers box. I'm not sure whether they've addressed this, but the version I have is designed incorrectly. If you know how bankers boxes work, and they haven't adjusted the design, you'll see what I mean when you go to fold one.
  • hochpt21
    hochpt21 Posts: 5,423
    I used something similar to a milk crate, but they were deeper and wider.
  • Easy Runnin
    12 inch Pizza boxes. Lay enough in to fill the box then tape it em up tight.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
    gudnoyez Posts: 8,066
    I would not go all out for transprting them. I would get some cardboard boxes a tad bigger than 12X12, pack them transport them and don't lay them or store them flat.
  • soundfreak1
    soundfreak1 Posts: 3,387
    Vertical pack not horizontal.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    pitdogg2 Posts: 24,583
    Hello go to the local 711 and steal all their milk crates out back.....
    It's what we did in the late 70's....
  • MrBuhl
    MrBuhl Posts: 2,419
    edited January 2018
    ^^ they resized those 70s milk crates. They no longer fit Lps these days! ^^
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    Viking64 Posts: 6,693
    edited January 2018
    MrBuhl wrote: »
    That is somewhat true. Although they don't fit "perfectly" as they once did, you can load them in such a way (angled) where you can get about 70-80% the number of albums in them. Plus, they are a bit lighter than if they were full, AND it gives you space to get your hands inside the "handles". win/win/win :)
    edited January 2018
    I think they're metric milk crates ;)
    One can still find vintage, LP-compatible milk crates.
    "Chance favors the prepared mind" (as Pasteur observed).
  • halo
    halo Posts: 5,616
    I like the idea of the boxes from the H.D. or the Sleeve City boxes. It's a 5 hour trip from Chicago to St. Louis. The move is less than a month away so, barring some freakish heat wave in February, heat is not likely going to be an issue. Thank you for all the replies! Much appreciated!
