Best method of transporting vinyl records?
halo
Hello everyone,
For those that have moved and have taken their record collection with them, what are some tips or tricks as to getting them there safely?
Best method of packing them? Packaging them?
And no, I'm not selling them or giving them away before I move. lol.
Thanks in advance!
Thanks in advance!
FWIW, I just used cardboard boxes, mostly of the Home Despot kind. Fill 'em full.
The best thing is to let the records transport you. Just darken the room, grab an adult beverage and let the music flow trough you....
Oh, you meant move them to another location. I get it now. I used a double walled box that was the same dimension as the record themselves and filled the box to capacity so there was no movement or shifting about.
How many to you have to sell? I mean move...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
You can get some wooden LP boxes/crates if you're worried about anything. Depends on how many you have and how you value them. If highly collectable, etc. I've seen guys use LP hardcases. (That's what I'd use for my 1st pressing sealed Wildflowers, etc.) Definitely fill whatever box you use to capacity as stated above so no movement or shifting.
Thanks for the input folks!
I don't need anything super indestructible, I just want to make sure the bottom isn't going to fall out of the cardboard box from the weight of the records. The double walled boxes at H.D. sounds like a good idea. I have ~ 70 records now? Some are not in that great of condition. Others are new or limited editions. So I'd like to try and see if I can get them all there safely.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Dollar for dollar the Home Despot boxes cannot be beaten -- that was feedback from one of my daughter's long-time friends, who has a moving company as kind of a side business (he's a tech guy of some sort). The heavy-duty boxes from HD are.... pretty heavy duty.
These are tough and good enough for long term storage if necessary. I bought some for my last move a few years ago.
https://www.sleevecityusa.com/ultimate-lp-storage-box-p/3strlpbox.htm
Not inexpensive or of the highest quality, but when I came out here to LA I brought about 200 LP's with me, I bought the LP crates from Container Store, the bigger concern is making sure they don't overheat in transit. Plus side is that these have handles, stack and are easy to carry (because of handles)VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I second this motion. I have about 30 of these I used to transport my LPs to the new house. They are real sturdy.If you can't hear a difference, don't waste your money. -
I just moved our record collection using over 50 boxes from U-Haul they were just right, but I got wore out lifting them completely full so I had to take 70% of the records out of each box near the end. Just about killed me. I could use them over for a couple of times.
I also have some of the Sleeve City boxes. Perfect fit. If possible, and you're driving, I'd maybe consider bringing them with you instead of in a moving truck?
Another idea would be the Container Store's "record crates". They're a little flimsy compared to real milk crates, and they're open, but they'd get the job done, though wouldn't protect against dirt/dust.
The Sleeve City ones fold like a bankers box. I'm not sure whether they've addressed this, but the version I have is designed incorrectly. If you know how bankers boxes work, and they haven't adjusted the design, you'll see what I mean when you go to fold one.I disabled signatures. -
I used something similar to a milk crate, but they were deeper and wider.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
12 inch Pizza boxes. Lay enough in to fill the box then tape it em up tight.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
I would not go all out for transprting them. I would get some cardboard boxes a tad bigger than 12X12, pack them transport them and don't lay them or store them flat.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Vertical pack not horizontal.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Hello go to the local 711 and steal all their milk crates out back.....
It's what we did in the late 70's.... -
^^ they resized those 70s milk crates. They no longer fit Lps these days! ^^VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
That is somewhat true. Although they don't fit "perfectly" as they once did, you can load them in such a way (angled) where you can get about 70-80% the number of albums in them. Plus, they are a bit lighter than if they were full, AND it gives you space to get your hands inside the "handles". win/win/win -
I think they're metric milk crates
One can still find vintage, LP-compatible milk crates.
"Chance favors the prepared mind" (as Pasteur observed).
I like the idea of the boxes from the H.D. or the Sleeve City boxes. It's a 5 hour trip from Chicago to St. Louis. The move is less than a month away so, barring some freakish heat wave in February, heat is not likely going to be an issue. Thank you for all the replies! Much appreciated!Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
