TL mod on original 2B crossover
hauxonhauxon Posts: 46
edited January 2 in Vintage Speakers
Just before new year the mail delivered a pair of RDO198-1 to my home. I'm going to use em for a TL mod for my SDA 2B's. I also have a pair of 5.6uF Claritycap ESA on my desk. Later I'm planning to recap the crossover using gimpod's boards but won't be ordering the parts until Ferbruary or March.
So should I mod the original crossover with the 5.6uF caps I have so I can fit the new tweeters ...or should I be (extremely) patient and wait until I have the everything? :open_mouth:
Polk SDA 2B Studio TL | NAD M51 preamp/dac | NAD C272 power amp | Chromecast Audio
  • nspindelnspindel Posts: 5,288
    So basically, you're faced with the complicated problem of deciding whether it's worth 30 minutes of work to be able to listen to the speakers for a month or two. Am I understanding the situation correctly?
  • xschopxschop Posts: 854
    Do you have to deal with USPS too?
  • hauxonhauxon Posts: 46
    nspindel wrote: »
    ...yes :grin:
    Well why not.
    xschop:
    USPS shipping was actually pretty fast to Iceland.
  • michaeljhsda2michaeljhsda2 Posts: 1,848
    Not sure if you noticed but the RDO198-1's negative terminal is larger that the SL2000's so you'll need to swap in a larger connector.
    SDA SRS 1.2TL's w/ RD0198-1's, Sonicap, Mills
    AI-1 Dreadnought
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 1C's stock
    SDA 2B TL's w/RD0198-1's
    SDA 2's (side by side tweeters) stock
    Yaqin MC-30L integrated tube amp
  • F1nutF1nut Posts: 40,206
    Wait and do it right the first time.
    F1, doesn't the TL modification put the extra 5.8uF cap in series with the factory 12uf cap?
  • westmassguywestmassguy Posts: 6,100
    xschop wrote: »
    It shunts the 2.7 ohm resistor forming a contour network, which is in series with the 12uf cap.
    To the OP, I'm sure you're itching to get the new tweeters in, but @F1nut is right. Wait till you have everything gathered up for all your internal upgrades, and do it in one shot. That way, you never have to open them up again, theoretically anyway.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    So theoretically, what is the new capacitance value of the tweeter circuit?
  • I took my 2bs a step at a time and found that I should have made a better plan. I would recommend as ^^ have stated. Do all your research, make a plan, buy all the right parts, then mod them once and for all. You will be happy you did jmho!!
    Yamaha RXA1030, Yamaha CD
    Polk SDA2btl highly modded
    Polk SDA 1C
    Polk CS350 LS x2
    Polk m5jr
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Toolfan66Toolfan66 Posts: 13,829
    I will be the "ECHO" in the room. Just wait till you have everything, and do it right the first time...
  • gmcmangmcman Posts: 1,178
    Yes.....wait.
    Get all your goodies, Install them on Gimpods boards. Dynamat all your baskets, then when you're ready to go, put them in a room with a cd on loop, if noise is an issue, face them towards each other about 1" apart, and let them go for about 2 weeks. They will cancel each other out for the most part facing each other but they will sound all over the place during the first few hundred hours.
    It's sooo worth it.
    Then listen to them.
Howdy, Stranger!
