bi-wiring rtiA5
anybody tried to bi-wire your rtia5? how does it perform after bi-wiring? I want to do bi-wire with my Yamaha RX-V2400, it has got speaker A B setup allowes to bi-wire. Any thoughts? Happy new year :)
  • gp4jesus
    gp4jesus Posts: 1,969
    if you have the wire, try it. expect others to chime in w/"don't waste your time."
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
    F1nut Posts: 49,804
    Simply replace the stock jumper plates with high quality speaker cable.
  • PixOtt
    PixOtt Posts: 15
    16 gauge and any recommended brands? thanks
    F1nut Posts: 49,804
    edited January 2018
    If you are stuck on gauge, it's not high quality speaker cable. However, it would be better than the stock plates.
  • gp4jesus
    PixOtt wrote: »
    start w/whatever you have though I'd go heavier than that between the amp/AVR and speakers.
    my $0.01
    PS: welcome to Club Polk if you haven't receive that
    Tony
  • soundfreak1
    soundfreak1 Posts: 3,387
    This is the "don't waset you time" that gp4 mentioned.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • the112player
    I use 14 gauge quad cable from blue jeans and am fine with it. Personally, I would spend my money on other things.....The biggest difference that I’ve noticed in my setup is the crossover mod on my RTi8’s. I used Sonicap caps and Mills resistors.
