What do use to stream music to your Hi-Fi ??
....and why ??
Looking to upgrade the $50 Gramofon I'm currently using for Spotify. Must support Spotify and Tidal. (I may step up to Tidal's lossless at some point) Remember it must be easy to set up as I'm as dumb as a bag of hammers. :)
Bill
Because I am The Pumpkinking
«13
  • treitz3treitz3 Posts: 12,397
    Bluesound Node 2 w/Musical Fidelity Tri-Vista DAC.
    Why? Good question. Probably price. 5 bills for the Bluesound Node 2. Very easy to set up. Lossless is worth it IMO but then again, so is an outboard DAC that doesn't support MDQ.
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
  • tonybtonyb Posts: 29,318
    Sonos for the simplicity, but it won't do higher than cd quality. If you want to go higher formats, Bluesound is another cheap alternative.
    Cheaper than cheap is chromecast, but not sure about their Spotify capabilities.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • pumpkinmanpumpkinman Posts: 6,102
    tonyb wrote: »
    I just found out that Sonos now does support lossless but will not support the MQA available from Tidal.
  • If you have a decent DAC I recommend the Chromecast "Audio" for an effortless streaming experience from most apps and servers.
    I do not own a DAC.
    I'm leaning towards the Bluesound Node.
  • BlueFoxBlueFox Posts: 10,053
    Lumin S1. It is an all in one solution; file player, streamer, and DAC. Does Tidal, and now supports MQA. You can't get simpler than the S1, and it sounds great.
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • DSkipDSkip Posts: 14,671
    Auralic Aries Mini if you can find one.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    ^^^ He keeps harping about this^^^
    To date? Have not heard it. Contender? Yes. Heard it? No.
  • SCompRacerSCompRacer Posts: 6,844
    edited August 2017
    I use an older Signature Sonore Music Server with Deux power supply. Basically a mini PC with custom power supplies (one for PC, one for USB card) and power filters for hard drive. It's fanless, no noise. Playback, no noise. SOtM-PCIe USB output card and SOtM drive power filter. I updated it with a small SSD card for the Linux op system and stuck a 6TB drive in it. I can also point it to an external NAS when the time comes. Controlled through a variety of third party aps with cell phone or tablets.
    Still using my DIY Dual Mono Buffalo III DAC with Sonore USB to I2S module. Discrete balanced output (no op amps). Sounds fantastic.
    If I didn't have that, I'd go for a Sonore micro or ultra Rendu. IIRC they added Spotify this year and it does Tidal. bikerboy just upgraded from the micro to ultraRendu. IIRC Carl (schwarcw) has the microRendu.
    http://www.sonore.us/microRendu.html
    A thread by Carl.
    http://forum.polkaudio.com/discussion/172912/sonore-microrendu-wuhoo/p2
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
    treitz3 wrote: »
    And it's not because I carry them. I can't sell these as I don't have any. They are great streamers that do everything under the moon.
    I'm not certain they do Spotify though so that may rule them out in this case. They do have Bluetooth connectivity though to open them up to any service you can use on your phone or computer.
    audiothesis.com/
    Cabling: Wireworld
  • txcoastal1txcoastal1 Posts: 9,787
    Simaudio 780D Dac and streamer
  • gcegce Posts: 2,146
    I just picked up a Marantz NA8005 for dirt cheap and it sounds great!
    Anaheim Hills CA,
  • afterburntafterburnt Posts: 4,425
    treitz3 wrote: »
    Tom, there are a few folks here that have them including me. I think it's a great piece, worth every penny and then some.
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
    Anybody compared it to the BS N2?
    I ask because I hate wasting money ad Mr. Pumpkin would want to know..
    treitz3 wrote: »
    I don't think you'll be happy with a streamer until you go up to the AURALiC Aries or something from Aurender. If your system is as revealing as you say it is, you should look higher up the streaming chain.
    audiothesis.com/
    Cabling: Wireworld
    That's what I am afraid of Skip. Spending more money for the same thing I have heard ever since streaming came about along the Hi-Fi world. There is always something missing....maybe I honed in on it when I brought it home for a direct comparison.
    Sub par sound, while at the same time. "close to CD quality".
    My version of "CD quality" and others apparently differs.....vastly.
  • mikeyb128mikeyb128 Posts: 2,735
    That auralic Aries mini is a steal, I have one hooked up to my Bryson BDA3, and I also brought it to my local hifi shop and hooked it up to several DACs. It's one heck of a performer, that you would have to spend a lot more to best. I have only spent a short time with its onboard DAC, which I found to be ok. Not exactly a fair comparison though, when being compared to something 8 times the price.
    2 channel:
    Theater:
  • Mikey081057Mikey081057 Posts: 5,367
    BlueSound Node2 into Marantz SA8004's DAC.
    Listen to Tidal HiFi an Masters.
    Sounds nice.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A23 x2 Amps Parsound Halo A21 Amp & P5 Pre | Marantz SR5011 AVR | Usher Dancer Mini-x DMD's| Usher BE-616 Center|KEF T100 Surrounds | SVS SB2000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Bluesound Node 2 | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC |Samsung 50" SUHD TV
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node | Audioengine P4 | Peachtree Nova 125SE |
    Closet | SDA SRS 2.3's | Monitor 5B's Yamaha M80 | Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2385
    Thanks for everyone's input
    Bill
    edited August 2017
    pumpkinman wrote: »
    Bill
    The Marantz streamer is a nice unit I would love to test, but they don't support Tidal last I checked. Apparently Music Direct is closing them out at $499, which is well under half retail price.
    audiothesis.com/
    Cabling: Wireworld
  • zuulzuul Posts: 253
    edited August 2017
    I use a (used around 250-300) mac mini with an audioquest jitterbug into a DAC then into my pre amp.
    For streaming I use Amazon music and for my digital collection I use Clementine.
    speakers:
    bowers & wilkins 685 S2
    polk psw-10
    components:
    sonic frontiers line 1 preamp
    sonic frontiers anthem amp 1
    mac mini w/ audioquest jitterbug
    teac ud-501 digital to analog converter
    oppo dv-980h dvd/cd
    interconnects:
    guzi rca
    monoprice onix series digital coaxial
    transparent performance USB
    transparent perfect image HDMI
    speaker wire
    audioquest type 4
    power:
    rhino-tek 1000w 15amp voltage regulator
    vansevers 211 power cord
    pangea ac-14 power cord
    tubes:
    amplifier: (2) NOS 1960 philco/lansdale 12AU7 (super rare!), (1) NOS 1967 mullard 12AX7, (4) 2016 svetlana hard blue EL-34
    pre-amp: (6) E88CC/6922 ??? (haven't cracked the case yet to see what previous owner was running...) so for now they are mystery tubes.
    misc:
    JRiver Media Center 24
    sanus 24" speaker stands
    auralex acoustics subdude II
    DeMoude Audio cylindrical bass traps
    rf/emi/noise reduction caps for empty rca inputs.
    Hall of Fame: [retired/sold]
    polk monitor series 5jr+ w/ RDO194-1 upgraded tweeters
    polk monitor series RTA 8T
    kenwood kd-550 w/ SME 3009 Series III tonearm grado gold cartridge
    adcom gfp-555II
    marantz 2238b
    luxman M-120A
    technics sl-b10
  • rooftop59rooftop59 Posts: 4,313
    Dude, @pumpkinman, DACs are pretty darn cheap now for some pretty nice ones (for those of us who play in the real world lol). I would seriously think about a Chromecast audio and something like a peachtree DACit: http://www.ebay.com/itm/Peachtree-Audio-DACiT-D-A-Converter-DAC-iT-/332340306078?hash=item4d6106a09e:g:TIUAAOSwmZdZjg9z and you would be set! Can beat that for under 300 bones!
    BUT, to use a chromecast you need a laptop, tablet, or smartphone that you can cast from. Its very simple, but you can't used it like some of the more advanced streamers.
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
  • Still using Squeezebox Touches throughout the house, 6 still going strong. The technology is dated now, but its been the standard to meet for about a decade. If not for Logitech abandoning the project and simply improving on a front runner from its price point it would still be the go to setup.
    Family Room HT 7.2/i]:
    Vizio P55-E1UHD Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Pioneer Elite N-50 Panamax M5300-EX
    Living room 2ch:
    Integra ADM 2.1 Teac EQ MKII Squeezebox Touch Fluance SX Speakers Panamax M5100-EX
    Upstairs media room:
    Vizio D1 32" Pioneer Elite VSX 32 Sony PS4 Squeezebox Touch Polkaudio Rti 6's fronts Polk CSR Center Pioneer 8" sub Panamax M5300-EX
    Master bedroom:
    Vizio VF550M Pioneer Elite VSX 33 Pioneer Elite BDP 80FD Squeezebox Touch Polk audio Monitor 40 II fronts, Rears Optimus LX5s Jensen CCS center Acoustic Audio sub Panamax 5100
  • Joey_VJoey_V Posts: 6,545
    Bluesound node2
    Joey's Gear:
    Current Gear:
    Torus RM15 -> Emm Labs DAC2x and TSDX Transport -> Cary SLP-05 preamp -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
    Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
    Old Gear:
    Speakers: BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source: Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification: Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased)
    Amplification: HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer: Infinity Entra2 sub -> SVS 25-31PC+ sub
  • nooshinjohnnooshinjohn Posts: 17,866
    Just picked up a McIntosh MS750 music server. I have only played with a few functions and listened to some Johnny Cash on it. This is amazing. I will be loading all my cds to it over the coming months and running it exclusively when not using the turntable.
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Krell Evolution 525a CD Player, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
    A budget would really help, these suggestions are all over the map lol...
    HT Rig:
    Master Bedroom
    Wife picked me up a Sonos. I'm still a vinyl freak but streaming is fun
  • Enjoy!
«13
Howdy, Stranger!
