Refreshing Black Veneer on a CS1000p
Inspector 24
Inspector 24 Posts: 1,308
edited April 2016 in Vintage Speakers
I've used this method on a few speakers before with good results. This guy had a few little dings and scratches in it, making it look a little older than it performed. Here's how I went about touching up the veneer of my black CS1000p.
First cleaning it with a light solution of Windex and water to get little bits of dirt/smudges off it, then allowing it to dry thoroughly so the next steps will be more effective.
Then, using a Minwax Wood Finish Stain Marker in Ebony I stain underlying wood a nice black, using a healthy amount on the bigger chip.
Then to blacken up the rest of the veneer and cover up other tiny tiny spots I stripe up the sides, then rub with a paper towel to distribute the stain. You can see the before/after in the half-done top.
I rub it out in 3-4 steps until the towel is near clean, then set it aside to dry for a couple days.
End result, a nicely refreshed blackness and hidden scratches.
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
  • boston1450
    boston1450 Posts: 7,478
    That does look nice. Great job. As heavy as that thing is - i can understand why it may have scratches here n there. Thanks for the tip
    Randy/Maine
  • vmaxer
    vmaxer Posts: 5,116
    Looking great.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • chefkungfu
    chefkungfu Posts: 638
    Great tip! Thank you for sharing and excellent work!
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • Inspector 24
    Yes, it is a heavy beast indeed. I've done this to a dozen or so RTx Series speakers so far, works great every time, always makes them look so pretty and new.
    Sounds awesome too. Great speaker for running Mono...In fact I bet two of them stood on end would make pretty great left and right channels!
    Up
    Down
  • Gatecrasher
    Gatecrasher Posts: 1,550
    That looks great! I'm going to try it on one of my SRT satellites tonight.
