A electronics/physics question about wire?
gimpod
gimpod Posts: 1,793
Before any of you go "Oh no not another wire thread", I think this is more an electronics/physics question and not just audio related.
Here's the question: What causes small gauge wire (I think 24 gauge and smaller) solid and stranded turn really stiff and break over time with use (less than a year). Any Ideas, I've had this happen with the last 3 hand control's for my hospital bed and with cheap small headphones.
    tonyb Posts: 32,906
    My guess is...air. Maybe they aren't sealed well enough.
    The wire itself breaks or the plastic coating gets brittle and breaks ?
  • gimpod
    gimpod Posts: 1,793
    The wire. It looks like it's sealed really good, I'd have to cut the controller open to see where the wire's broken. I think it's broke where the wire go's into the controller. If you hold it just right it works but move it a little and it quits working.
    pitdogg2 Posts: 24,582
    gimpod wrote: »
    Sounds like the ol bread tie. If you move it back and forth a little she'll break at least that is what it sounds like to me. Thin enough to not take much back and forth movement.
    mhardy6647 Posts: 33,049
    edited March 2016
    wire breaks when repeatedly flexed Indeed, that's how I was taught to break off a length of solder by my father long, long ago :- ) Just wiggle it back and forth, and it breaks.
    That's what caused the original DeHavilland Comet jet liners to plummet from the sky -- metal fatigue (stress cracks) caused by strain of pressurization/depressurization cycles (flexing) at the stress points caused by its (fairly large) square passenger windows. oops.
    http://www.uh.edu/engines/epi112.htm
    https://en.wikipedia.org/wiki/BOAC_Flight_781
    Not electronics, it's physics. Metal fatigue.
    https://en.wikipedia.org/wiki/Fatigue_(material)
    My belief/understanding has been that the bending induces (or deforms and reforms) microcrystalline regions in the area being stressed, which somehow potentiates the ultimate failure of the (in this case) wire. That may not be accurate, but it's comprehensible. :-/
    Dammit, Jim, I'm a biochemist not a metallurgist! ;- )
  • gimpod
    gimpod Posts: 1,793
    I think you guys are missing the point. I know about "Metal Fatigue" all to well I've broken the back of just about every wheelchair I've owned.
    The wire starts out being very flexible but over time (about 6 months or so) it starts to turn really stiff and then breaks. It's not the sheathing it doesn't show any signs of cracking or breaking, it's the wire.
    I think it's cheap wire and it's gauge is to small for it's use. I think it's the voltage and/or amperage that's causing the wire in the cable to change it's properties.
    It's diameter is about 2/3's that 'of a cat 5/6 cable with 12 wires. I'd just say screw it and make one myself but it uses what looks like a 8-conductor RJ-45 modular connector that has 12 conductors. I think it's a custom made connector cause I've not been able to find one. If I could get at the connectors on the bed I could change them but that would most likely void the warranty.
    I just wish company's would make things that last. I guess I'll have to get the VA to order a new one again but that is such a PITA.
    Everything in your post that I read sounds like metal fatigue to me, so I'm out.
    Sorry.
  • gimpod
    gimpod Posts: 1,793
    Sorry.
    @mhardy6647 Don't be sorry your right it is metal fatigue that's causing the wire to break. The question I'm asking is what's causing the wire to get so stiff that metal fatigue becomes a problem. When it's new the wire is as flexible as say the wire on a good set of headphones and then gets stiff and breaks.
    BTW: I had the same problem years ago when I would get those cheapo $3 - $5 headphones for my T.V. from Rat Shack (Long before HD and Widescreen T.V.s)
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    It sounds like it is missing a strain relief as it exits the casing. This could be remedied with some heat shrink at the exit point on the next replacement of the cable. Since this is being used in the healthcare area instead of the retail market, there isn't a return rate being tracked to cause a recall to be issued.
  • afterburnt
    afterburnt Posts: 7,892
    edited March 2016
    gimpod wrote: »
    Sorry.
    Well I think it is the same issue as when you resize brass too many times. I think they call it "work hardening" or something like that. It simply becomes brittle from repeated flexing, expanding and contracting etc. Annealing (heating it) the brass can extend its life. But I guess you cant take a torch to your wires.
  • rpf65
    rpf65 Posts: 2,127
    Coild somply be something with the manufacturing process. In this instance that's what I would lean towards.
    Impurities in the metal, bad temperature control in the extruded, or fluctuating temperature/humidity in the processing area. Unusual or custom connecter would mean a specific manufacturer.
  • Speedskater
    Speedskater Posts: 495
    Yes, it's "work hardening". Soft copper wire when repeatedly flexed turns into hard copper wire.
    tonyb Posts: 32,906
    Gotcha Tony,
    I'm assuming it always breaks at the point of the most flex, at the bottom of the controller ? Is it possible to put something harder over the wire like harder plastic making it more stiff and not as flexible ? It would also have to attaché to the bottom of the controller....super glue, small screws, etc.
    Another option is to affix the controller to something a tad bigger and solid, maybe on a stand next to the bed or attached to the bed itself, so the wire stays in one position and isn't always flopping around. Don't know if that would work for you in your situation though.
  • lightman1
    lightman1 Posts: 10,776
    How about a strain relief coil at the base of the controller where the lead wire is attached?
  • afterburnt
    edited March 2016
    dunno if this helps but I seen one of these "life hacks" or something where you thread a spring from a "bic click" type of pen onto the cable to keep it from flexing too much at the junction Maybe what lightman is talking about?
  • lightman1
    http://www.oushengnb.com/strain-relief/xx019-1091.html
    Just need cable diameters. I've used them on a several jobsite temp power boards. Lots of SO cords feeding sub panels many floors vertical. They stand up to some serious abuse. Have a look at the controller pad and where the wire exits. Might help stop what's happening to the cable. See if the VA will chip in for it.
    Just saw that it's about the size of CAT5 cable. They should have something along that size.
    This is just one of several suppliers in the industry.
    Good luck and let us know if we can help.
    Salute! Good veteran! Thumbs up!
  • leftwinger57
    leftwinger57 Posts: 2,917
    When I was working w/ an electrician he used these strain relief devices he affectionately called Chinese handcuffs. Of course these are for more industrial use. Why yours failed is just over use and it found it's weak point and breaks. In the cheapo headphones the wire used is hair thin and for a bed /nurse caller just the weight of the thing being slung over,dropped, wrapped around the bed rail over thousands of times, again finds the weak spot and breaks.
    https://www.fruitridgetools.com/electrical/cable-grips/leviton-industrial-straight-male-strain-relief-liquid-tight-cable-cord-grip-3-4-npt-l7903/
    http://www.mcmelectronics.com/product/21-14335?utm_medium=cse&utm_source=bing&utm_campaign=bing
    I believe I have some 24 gauge clear-coat wire around here that is 15 years old and has been in a ball for most of that time. It seems perfectly flexible no hardening, no splitting, none of the problems mentioned above.
    So the question! Is unused wire immune to these effects or is this unusual?
    the hardening comes with (repeated) mechanical deformation, a single round (i.e., coiling it up once) will cause some stress fracture, but not enough (usually) to contribute to (shall we say) macroscopic stiffening nor failure.
    So... yeah, the advice re: strain reliefs given to the OP by (pretty much) everyone so far seems prudent.
