Lsi9
11tsteve
Well, a couple of months back, I bought a pair of Lsi9 from cstmar01 for a very nice price. They have some cosmetic issues, which I knew about, but sonic-wise are fine for stock. In fact, I put them into the system, and they mesh very well with what I have going on. Everything I have for speakers are updated vintage, and I wanted the Lsi9 to give a more modern speaker design a listen.
Compared to the rest of my stable (all of which I enjoy for differing reasons), the presentation and pinpoint detail of the Lsi9 is quite pleasing. They just slid into my system, and I have done nothing but enjoy my time getting to know them.
So, I have decided to move forward and put some work into them. Crossovers will be modded, and I spent the afternoon removing the side panels. These are second gen and glued on, so it was some work, but nothing horribly difficult.
I feel overwhelmed, more so than previous projects, just because these are not quite as straight forward a project as, say, 5 Jr+.
I will re-veneer the side panels (thinking burled something, or tiger striped maple), and I would like to refinish the cabs. The piano finish has some damage, and needs to be either repaired, or completely redone.
Right now, my main two questions are...
How to remove the glue from the cabs and side panels.
And the best way to remove the original piano black finish?
I think I want these to be my main speaks for a while. They really trip my trigger and work well with my McCormack... so I want to do these right.
Steve
I was thinking Sonicap Gen 1's and Mills for the crossovers. Anyone had better luck with others?
Steve
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Keces DA-131 mk.II
Post edited by 11tsteve on
This morning, I ordered the veneer for the side panels. I have three sets of speaks done in varying forms of oak, and I wanted something different for the Lsi9... something figured. After spending a few hours at Veneer Supplies, it came down to burled walnut, burled white oaf, and burled maple. I chose the maple.
There is not much paper backed figured veneer, so I bought a lot of 9 sheets of raw veneer. This will be my first foray into using raw veneer, so if anybody has any tips, they will be appreciated.
I still haven't come to a conclusion about the crossovers. By the time I purchase everything I need for a DIY, I am getting close to the cost of fortress level crossovers from VR3.... the thing I am caught on is the low end. I would really rather add the film caps instead of a bypassed electrolytic. I have been studying Ray's thread on his Lsi9 mods, and will most likely go that route.
So many decisions.
This weekend will be spent stripping and prepping the side panels.Polk Lsi9
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Been pretty busy of late, but I found some time this weekend to finish stripping the veneer from the side panels. All in all, it went much better than stripping the vinyl from the RTA 11T's or the 5jr+'s.
I have today off due to weather, so I get to start sanding the panels down, and I have applied veneer softener to the sheets I have decided to use.
Polk Lsi9
Keces DA-131 mk.II
Also, as a side note, I used Goof Off super glue remover to clean up the residual adhesive from the side panels, and I must say it seems to be an excellent product, dissolving the dried glue in a matter of a couple of minutes. I scraped it off with a sharp putty knife, and it seems to leave nothing behind.
http://www.goofoffproducts.com/product/pro-strenght-super-glue-removerPolk Lsi9
Keces DA-131 mk.II
Very cool. I've used goof off before with great results, seems to remove any kind of glue residue with ease.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
New sidenote to my audio journey. My McCormack DNA 0.5 will be making the trip to SMc Audio for the Gold Standard upgrade.
When they are finished, about all of the original amp that will be left is the chassis, the transformer, and the output boards. All new everything else, including the main board.
Turnaround should be 3-4 weeks, so hopefully I can get this Lsi9's put back together in that time.
Not to mention, my ears will probably be bleeding by then from listening to my old NAD 2150....
I am experiencing difficulties with the veneer. I believe I didn't initially apply enough of the softener, and so I am going through a second process of trying to get the veneer to be more pliable.Polk Lsi9
Keces DA-131 mk.II
anonymouse wrote: »When I did my CRS+ in raw walnut veneer, I used normal wood glue, covered the veneer fully with a thin but adequate layer, let it dry to just tacky, and then ironed it on with a regular clothes iron with a barely damp cloth between the iron and the veneer. This worked really well. I was even able to do rounded corners easily with this technique. Over 4 years later, I have not had any separation problems with the veneer. I would try this technique vs. your softener technique.anonymouse wrote: »Also, for your crossovers, splurge on sonicaps for the highs, go with daytons for the lows. You will be happy with the results.
Thanks very much for the tip! I had reapplied the softener a few days ago, and I had much better success with the sheets being pliable this morning. I barely misted a towel this morning, applied the glue (I have a veneer glue), let it set just a bit, and tried the iron. I worked well in getting the sheet flat and getting the veneer to bend around the curve. The panel is currently in clamps, so well see what happens.
I am starting to wonder if maybe contact cement might be better for this project though. The positioning of the veneer is not critical in this case, so the disadvantages of the cement aren't a big deal.
I did order crossover parts, Sonicap Gen 1 for high/mids, Mills 12v all around, and 2 Solen 130 uF for the low pass. I also ordered some Derlin and Cardas QE solder.
All I need is some good hookup wire, but I don't really know what I want.
I am going to try a mix of DarqueKnight's thread on modding, and attempting building a new crossover using point to point wiring in a VR3 style.
I built entirely new crossovers (with Trey's help) for my Infinity Rsb, and it was very challenging, but the results were very satisfying. The Lsi 9 will be a bigger challenge. With the Rsb, the 10 inch woofer cutout made design and installation was easy.Polk Lsi9
Keces DA-131 mk.II
progress. I haven't decided what route to go with finishing though....
Polk Lsi9
Keces DA-131 mk.II
I started getting some color into the grain of the panels today, using 2 Minwax products. First a pre-stain treatment, and then I am using a natural stain.
I have a compare picture to start with, and more as I get further along.
The pre-stain went on, was allowed to sit for an hour or so, and then the first application of stain. I got all four done with the first round today, and lightly sanded, ready for the second round tomorrow.
While they were drying, I got a start on the crossovers. I am using Derlin for the boards, which I cut to size using the dimensions of the stock board. I used my Rockwell oscillating multi-tool, which went smoothly. I just had to sand the cut edges a bit, as the tool burrs the plastic a little.
I did a mock up, drilled for my zip ties, and got one about ready for soldering in the morning. Should have put a quarter in for scale to give an idea of those BigBoy 130 uF's. That board will somehow be attached to the bottom of the speaker cab as I did with my Infinity Rsb's. I just don't yet know how.
I drilled and tapped the stand-offs on the stock backplate, and have some 8-32 ReadyRod I am going to use to mount the mid/high boards, a la Fortress mod. I wanted to possibly build a new backplate, using some 1/4" Derlin and 1/8" brushed aluminum plate, and also drop one set of binding posts in that process( I will never bi-amp these), but I am running out of allotted time. That is something I can still do later.
Polk Lsi9
Keces DA-131 mk.II
Looking good Steve.
Looking forward to the completed project. Then you can make a matching computer case! (Throwback reference to our time on Extreme Overclocking for the win!)"Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I wish I'd seen this earlier. Since you are not adding color there's no reason to use a pre-stain or clear stain at all. Just finish them with the clear coat of your choice. If you have spray equipment, nitro lacquer would bring the grain out beautifully.Political Correctness'.........defined
President of Club Polk -
Now, in retrospect, I know I should have maybe asked some more questions. Though I am just a poor home hobbyist with little access to nice equipment such as a sprayer, there may have been a better avenue. Using the products I did, with a light polyurethane, has added a reddish hue. For all I know, this may have been a natural aspect of the veneer and unavoidable, but I was seeking something a bit more on the blonde side.
That being said, I am in no way disappointed. I still like the panels immensely, and they are a vast improvement over the grey beat up old veneer.
So they are drying, and I may add another coat or two.
Meanwhile I have about wrapped up my crossovers, nearly ready for install.
I still have to drill, add hurricane nuts, make new gaskets, dynamat the drivers, and I think I probably want to re-attach the side panels before I reinstall the drivers and crossovers.
My plan is to use Loctite PowerGrab, unless there are other suggestions?
Polk Lsi9
Keces DA-131 mk.II
No doubt, they look WAY better than the stock ones.
Power Grab needs one surface to be porous otherwise you'll need to use something else.
I mistyped... or I should say, mis-identified the product. I have a small consumer sized tube of Loctite PL Premium 3X. I have used the construction adhesives for work related projects, and knowing how they perform, the only concern I would have is the possible need to remove the panels at some future point.
Polk Lsi9
Keces DA-131 mk.II
Try clear double sided 3M tape. With that you would be able to remove the panels in the future.Political Correctness'.........defined
I took your advise, and I thank you very much. It had crossed my mind to do this, but was not confident with that choice until a more experienced person gave the ok. I bought the heaviest duty, and it seems to be working like a champ. The only downside is the very small gap between the panel and the cab, but it is barely noticeable.
Just finished them up this morning. The piano black finish is not super great, but I tried to buff it up best as I could.
Just Got the system changed back around, and I am loving the combo of the upgraded McCormack and Lsi9 together. some pretty sizable caps in the new crossovers, so I imagine between the amp still needing time, and the speakers needing a lot of break in, things will be changing a bit here and there over the next couple of weeks.
A reminder.....
Some crappy phone pics for now...
Polk Lsi9
Keces DA-131 mk.II
Very NiceHome Theater/2 Channel:
dhsspeakerservice.com/ -
WOW I like it!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Very nice!
Great job.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thank you for the kind words.... as with anything, I put a lot of effort into these, but there are still some imperfections.
Working with burled, raw veneer for my first attempt of not using backed veneer was a lot to bite off. And with the tight cab design, the crossovers were a challenge. The board with the 130uF caps literally has maybe 1-2mm between it and the top of the main crossover.
But overall, I am very pleased with the results.
Polk Lsi9
Keces DA-131 mk.II
Let me pick my jaw up off the floor... They are gorgeous!Stan
Main 2ch:
HT:
Other stuff:
Yep, gorgeous. Congrats!b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
those LOOK awesome man. Nice job!
Now, how do they sound???Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Last night, I came home from a hard day, everyone was on a surprise outing, so I had some unexpected speaker time.... with some serious sound pressure. And between the "new" amp and the Lsi9... well... I just couldn't get enough. I was overwhelmed by my happiness at what I heard. Everything I put in sounded more in-the-room than I have ever heard... more weight, more dimension, more air.... incredible height, depth... it's new amp, speakers, and cables, and it is all as one.
Then this morning I had a little time. I would not think it will ever sound crappy again, but it was quite the transporting experience. Was it morning? Was it mood? Or is it that I am in the middle of break-in?
This is my fourth set of speakers I have broken down and refurbished as completely as I possibly can, and I know this always happens in the first week or two. So the best I can answer you question is " they are going to sound ****ing awesome, but need a little time".
Polk Lsi9
Keces DA-131 mk.II
Looks Great!! Love the finish!
Looks beautiful! Bring em down to the Quads and I'll break em in for ya.
Enjoy the fruits of your labor. -
Nice job!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I just saw this, those are stunning. I love maple and the burl is beautiful.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Thanks guys! Couple of months later, everything settled in, and it's all sounding pretty sweet.
Now it's time to start playing The Cable Game.Polk Lsi9
Keces DA-131 mk.II
