SDA-CRS/CRS+ Something Different
    F1nut Posts: 52,276
    You'd want to keep that monster away from the tweeter inductor.
    xschop Posts: 5,728
    Was afraid of that. Would have been nice to have all be right there accessable by 4 screws.
    F1nut Posts: 52,276
    Remote mount it with faston leads to the board like Polk used.
  • westmassguy
    westmassguy Posts: 6,850
    Like Jesse says, you want the SuperQ as far away as possible. Difficult in the CRS cabinet though, since you don't want it near the woofer magnets either.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    xschop Posts: 5,728
    I'm changing out the factory inductor leads also to 16g OFC with a little extra length.
    I noticed there is an "R" and a "P" on the board. Does it matter which way they are connected to factory inductor inputs?
    F1nut Posts: 52,276
    No
    xschop Posts: 5,728
    edited January 2018
    This is the 2nd set of factory CRS+ crossovers I've found and removed these bypass caps. Why the 1000 at 50%?
    F1nut Posts: 52,276
    Probably all they had on hand at the time. It's how things worked at Polk back then.
    xschop Posts: 5,728
    Cap tolerance must have come a long way since then.
