SDA-CRS/CRS+ Something Different
You'd want to keep that monster away from the tweeter inductor.Political Correctness'.........defined
President of Club Polk -
Was afraid of that. Would have been nice to have all be right there accessable by 4 screws.Don't take experimental gene therapies from known eugenicists.
Remote mount it with faston leads to the board like Polk used.Political Correctness'.........defined
Like Jesse says, you want the SuperQ as far away as possible. Difficult in the CRS cabinet though, since you don't want it near the woofer magnets either.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I'm changing out the factory inductor leads also to 16g OFC with a little extra length.
I noticed there is an "R" and a "P" on the board. Does it matter which way they are connected to factory inductor inputs?Don't take experimental gene therapies from known eugenicists. -
NoPolitical Correctness'.........defined
This is the 2nd set of factory CRS+ crossovers I've found and removed these bypass caps. Why the 1000 at 50%?
Probably all they had on hand at the time. It's how things worked at Polk back then.Political Correctness'.........defined
Cap tolerance must have come a long way since then.Don't take experimental gene therapies from known eugenicists.
