Down & Dirty 800v/a Dreadnaught
MrBuhl
MrBuhl Posts: 2,419
edited October 2015 in DIY, Mods & Tweaks
Picked up a used and slightly abused (in shipping and not to me, previous incident to be clear) "Larry case" from @GlennDog & ordered the correct Avel/Lindberg toroid quite a while back. Finally got around to construction about two weeks ago.
Once again, I copied @westmassguy's excellent and very fine design for mounting, (at least in the very Joe homeowner way I'm capable of) and I was off to the races. This one doesn't make use of the copper foil of Dave's full-on designs because it already was coated with Dynamat when I received it. Also, it was drilled for RCA's and not Speak-On's on the box.
The incredibly helpful and resourceful @helipilotdoug hooked me up with Canare 4s11 for SDA cable, Speak-On connections for the 2b speaker cups, some very nice gold coated copper RCA binding posts at the Dreadnaught end, and some copper Furez spades to make up new Canare speaker wires as well.
While I was at it, I installed the "Larry Rings" I've been sitting on since the last run were produced, BH5 behind the woofs, sealed the magnets and cabinets with LocTite Powergrab, Dynamated the baskets, and upgraded the binding posts in the cups when I added the Speak-On connections. I also removed the false bases. The only thing left is to upgrade the crossovers on the 2b's now!
1.rackcdn.com/polkaudio.vanillaforums.com/editor/9w/gy4iu1b63yig.jpg
Burn in has begun, but man they still sound so sweet on the new Dodd with the Treasures!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Post edited by MrBuhl on
  • agfrost
    agfrost Posts: 2,464
    Cool!
    How'd you decide to cut/install the BlackHole 5? One of a couple things I'm dragging my feet on for my 2BTLs.
    Jay
  • westmassguy
    westmassguy Posts: 6,850
    Looking good Ed
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • MrBuhl
    MrBuhl Posts: 2,419
    edited October 2015
    Thanks Dave - the crossovers next I think! It's a two-piece though - is that what you'd expect? I don't think I'd had them apart yet when we discussed them.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    agfrost wrote: »
    Cool!
    Thanks! I followed the recommended for my 1c's honestly, I just assumed it would be the same. Size was somewhat dictated by the BH5 I had on hand as well.
    I cut out rectangles that fit between the brace and sidewalls to go just behind the mid-woofers as you would with the bigger brothers. Hope I was correct - they sound great anyway!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • westmassguy
    MrBuhl wrote: »
    Split/two piece? Doesn't sound right Ed. Can you send me a photo of the crossovers?
  • MrBuhl
    MrBuhl Posts: 2,419
    I thought that seemed wonky Dave!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • westmassguy
    Ed, those are 2A crossovers, not 2bs. The Dreadnaught should not be used with them.
    It will not allow you to use a non-common ground amp.
  • MrBuhl
    MrBuhl Posts: 2,419
    BTW I assigned +1 to blue/black and -1 to white on the sda cable connections, nothing blew up so I assume I got it right! (based on same +1 / -1 at the Speak-On i used on the 1cs.)
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    edited October 2015
    Crap! So all this time they've been 2a's and not 2b's! I don't suppose it's possible to switch them to a 2b crossover if I purchased a pair?
    Would also maybe explain the Dodd 50w popping the occasional fuse I imagine?
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • westmassguy
    edited October 2015
    MrBuhl wrote: »
    You can convert them to 2Bs, with a new crossover, and 2 new MW6511 woofers.
    Do not use that amp with them.
    heiney9 Posts: 25,409
    What was so special about the Avel Lindberg for this application? Parts Connexion has Pilitron's on sale @ 60% off.
    I wonder if they have a comparable unit to the 800VA A/L?
    http://partsconnexion.com/plitron_transformer.html
  • MrBuhl
    MrBuhl Posts: 2,419
    My understanding is selection is based on specs provided to @DarqueKnight from MP hisself, that this was the preferred choice. So that's what I went with!
    http://forum.polkaudio.com/discussion/74472/the-ai-1-dreadnought-project-pt-1/p1
    Other than being a sheep and following what I was told, I honestly can't say why the Avel 800 is the right one for this application LOL!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    I can look through the lengthy archives I suppose. Thought maybe someone could give a quick answer.
    They have a 2000VA Pilitron, but I can't remember what specs are important.
  • MrBuhl
    MrBuhl Posts: 2,419
    It's on page 1 if you want to look, right under Fig 8.1 picture.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • drumminman
    drumminman Posts: 3,396
    Somone a while back sent DarqueKnight a plitron which he compared to the A-L in listening tests. He thought the A-L sounded better. This is all from memory - perhaps he'll chime in.
    MrBuhl wrote: »
    Yes, that's helpful. The spec sheet for Pilitron doesn't have any of that info.
    I was just looking at saving a buck. 60% off is a decent discount, but if nothing fits the spec then I'll move on.
    I should have just pulled the trigger on Mr. Buhl's.....lol.
    Actually, I had one at one time (just the transformer) and sold it because it was sitting in a drawer not being used. I think that was before many decided even with a common ground amp the isolation transformer sounded better.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    drumminman wrote: »
    Here is the thread:
    http://forum.polkaudio.com/discussion/131537/plitron-1000va-transformer-evaluation
