How to test possibly blown Peerless Tweeters??
Nules75
Alright, this is my first post!! I'm trying to get to 100 posts quick so I can buy some speakers here!!
I just picked up a pair of 10A's for $40. Now I know why they went for only $40. There's lots of issues with these speakers. I will have to replace all of the mid-drivers as two are frozen and the others are rubbing. The crossovers don't look to be in the best condition either and I intend to replace them. When I tried to listen to the speakers they made no sound at all. So, I've pulled the tweets and I would really like to keep and use them. How can I test them when they are not connected to the crossover? I did test with my multi-meter and got inconsistent results......but, the most consistent result is 0 ohms...
Ideas?
Thanks in advance!
Thanks in advance!
On the losing end of a wishbone and I won't pretend not to mind...
Use the speaker wire that's going to the back of the 10A. Turn the bass all the way down, any type of loudness switch off, and volume all the way down first.
Edit: and don't turn it up very high.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I'm guessing it doesn't matter which wire goes to which terminal on the tweeter? I don't think the terminals are labeled and of course I don't remember which wire went to which side!On the losing end of a wishbone and I won't pretend not to mind...
There is a positive and negative connection for the tweeter and drivers, so yes it matters.
Before doing anything else, check on binding post plate for a fuse. It's there to protect the tweeter from damage. If it's bad, the tweeter will not work.Political Correctness'.........defined
President of Club Polk -
At the top of the page UPON opening Vintage Section here - there is thread's that will assist you in wiring/tweter/driver info
Welcome to PolkRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Ah, yes....the fuses. The d-bag that had the speakers before me put tin foil around them.....so, nothing to blow....except the tweeters, right? I think I'm kidding myself in thinking the tweets will still work as he probably blew the tweeters since he put the foil around the fuses. Hoping for the best....On the losing end of a wishbone and I won't pretend not to mind...
Use 1a fast blowing fusesRandy-Maine
by David WMG
Question.....since the previous owner decided to put tin foil around the fuses, basically providing no protection...is it possible the tweets didn't blow and maybe just damaged the crossover instead? (crossing fingers)On the losing end of a wishbone and I won't pretend not to mind...
Seriously? Tin foil? You shouldn't have even paid $40 for these, they should have been paying you to take them.that had the speakers before me put tin foil around them
You're going to be in these for at least $300 just to get them going, maybe more. One persons opinion: they aren't worth it.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Yeah......I hear ya. I had been trying to find some 10's with the rosewood finish forever to match my 7's and since I don't see many 10's listed often, especially with the Peerless tweeters, so I bit.....plus I had just driven 25 miles at my lunch break and did'nt want to leave empty handed! At least I was able to talk him down from $125!! My next issue is deciding if it's worth it to replace some items on these or just wait for a new pair to show up someday.On the losing end of a wishbone and I won't pretend not to mind...
You could get a pair of RTA-12B/C's or SDA 2B's for $300afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Right now, if the tweets don't work I just plan to switch them out with the SL2000's from my 7's (once I get the RD0-194's) to get me by for now. I found used crossovers for the 10's for $7 on ebay, so basically just need to replace the mids. Ugh....probably need to just find a new pair.........On the losing end of a wishbone and I won't pretend not to mind...
You can't use an SL2000 in place of a Peerless, for one the holes they mount in are different sizes and for another the crossover would need to be changed.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Right, the used crossovers I found are for the sl2000's, not the Peerless thankfully. My intention with these was/is to make them a restoration project....obviously, I was hoping the tweets would at least still be functional and I could've just upgraded the crossovers. So, wish me luck when testing the tweets when I get home!!!!
On the losing end of a wishbone and I won't pretend not to mind... -
Yep,, tweets are toast.On the losing end of a wishbone and I won't pretend not to mind...
Thats why they use a fast blow fuse. To keep tweets safe. To wrap foil on fuse & over volume them = disaster. If the cabinets are in decent condition & you get lucky on parts. It may be worth it. The 10's are a great speaker. Lots here have them & enjoy themRandy-Maine
by David WMG
Yeah, I have no idea why he would have put foil across them. The cabinets are good. So, I think I'll make a project of them.On the losing end of a wishbone and I won't pretend not to mind...
MW audio sells a drop in replacement if you want new. I haven't heard them myself, but supposedly they sound close to the originals. https://www.midwestspeakerrepair.com/mw-audio-mt-4115-1-inch-dome-tweeter
The peerless tweeters show up a lot of ebay too of course.
Why are you replacing the xovers? -
One of the crossovers appears burnt/leaking. I was hoping that was going to be the reason the tweeters weren't working....no such luck. I just happened to find a set on eBay that matched what I have already....they were only $7 and look great. I don't have the time or money to do the actual crossover upgrade right now, so I decided to just pick up the matching used crossovers for now.On the losing end of a wishbone and I won't pretend not to mind...
I have a pair of the Midwest Speaker Peerless clones. They sound close to the Peerless. I currently am not using them. Pm me if you are interested in them. They have low hours on them.
