Fuses on vintage speakers
I have a pair of Vintage Monitor 10s with the double fuses. The fuses need to be replaced, but I cannot read any information on the old fuses. What type of fuse is needed. Are the top and bottom fuses the same....any help would be appreciated.
  • Nightfall
    Nightfall Posts: 10,086
    1A fast blow
    afterburnt wrote: »
    Village Idiot of Club Polk
  • westmassguy
    westmassguy Posts: 6,850
    The top fuse is for the Tweeter, so 1 amp fast blow.
    The bottom fuse is for the woofers. I'm guessing 3 amp fast blow.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • drumminman
    drumminman Posts: 3,396
    My RTA 12C's came with 0.75 amp fast blow. Not sure how much difference it makes, but I'd be cautious protecting the tweeter section with a 1 amp.
  • Nightfall
    edited April 2015
    drumminman wrote: »
    I remember reading an old RTA-12 review that said 0.75 amp, I was wondering about that. I wonder if it's to account for the fact that cheap fuses aren't exactly accurate.
    afterburnt wrote: »
  • Zenkman
    Zenkman Posts: 3
    Thanks for all the great input. Can you please explain fast blow. Is that different than a normal type of fuse. Would I have to ask for it by name. Does it really matter if it is a 1A 2A or 3A fuse.
  • Nightfall
    edited April 2015
    You could bypass the fuses all together (or put in a much higher amp fuse) if you wanted, you just run the risk of frying your drivers if you run your amp into clipping. Having the correct fuses is a safety net.
    afterburnt wrote: »
  • Nightfall
    afterburnt wrote: »
  • Zenkman
    Zenkman Posts: 3
    That helps a lot! Much appreciated.
  • nspindel
    nspindel Posts: 5,343
    If you look at the original Monitor 10 schematic, which was for the Peerless tweeter, it specifies a 1A Fast fuse. When I rebuilt a pair of 10A's I used these:
    http://www.amazon.com/gp/aw/d/B000CZ2YRU
  • My recently purchased 10B's have weak polyswitches and I am not ready to do the XO upgrade yet. Can I short the polyswitch by twisting it and put a .75 or1 amp fast blow inline fuse on the positive wire going to the tweet for protection until the rebuild?
    After reading the different post on the upgrades I didn't hear anyone speak of replacing the wire from the XO to the speakers, why would this not be done while in there?
    And if I put an inline fuse for the tweets could I put a 2.75 or 3 amp fast blow in for the mid woofers also?
    You may ask why all the protection? I have lower power amps 125w max and teenagers that have access to this set-up and I sometimes have drunky ears while listening myself. Not doing the XO upgrade yet leaves a fair amount of change for the purchase of a better amp which is higher on my list as I have other speakers that I am wanting to put some real power behind.
    Any advice on the technical aspect of this is appreciated. Though I expect some comments on the teenagers and drunken ears to be forthcoming.
    Thanks, Cooley.
  • cortico
    cortico Posts: 587
    edited September 2015
    cooley53 wrote: »
    Thanks, Cooley.
    The are post in regards to the internal speaker wire upgrades.
    I have done it, but honestly, it's such a short distance. Unless the exiting wiring is corroded or damaged, it would be hard to notice any other improvement than aesthetics.
    Post edited by cortico on
  • Thank you very much.
    Cooley
    pitdogg2 Posts: 25,208
    cortico is correct I second that. When I did my SDA's I did redo the wire it was because the former owner had tried to make them something they were not....lots of splices...
