Monitor 10B - Crossover Upgrade Parts Confirmation
  • FestYboy
    FestYboy Posts: 3,861
    ^ nylon stand offs, they can be had at Lowe's or home Depot in the hardware section.
  • westmassguy
    westmassguy Posts: 6,849
    The nylon standoffs are available at home depot or Mouser & Digikey. The gasket is original.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • JesseS
    JesseS Posts: 14
    Westmassguy - did you extend the leads of the top mounted capacitor and run them back down through the board on the bottom to solder? If so, they must be carefully routed or insulated around the lower mounted stuff? Thx!
  • westmassguy
    JesseS wrote: »
    #16 gauge insulated hookup wire.
  • JayMX
    JayMX Posts: 464
    edited July 2019
    I used long screws and nylock nuts to support my secondary boards when I rebuilt my Monitor 7 crossovers. I extended the leads by soldering on cutoff solid lead pieces from some other components then heat shrink over them to insulate. Worked out great!
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • JesseS
    JesseS Posts: 14
    JayMX - those look very nice! I ended up stacking the caps with hot glue. I didn't realize metal screws would suffice, and the plastic standoffs and threaded posts added up to about $45...
    Anyway, all said and done, the speakers sound odd to me now. I don't hear bass guitars with clarity, though I do hear lower bass and higher mids. The tweeters sound great, but there's a muddiness / quietness to that particular frequency range of the bass guitars in rock music, lower mids / bass - almost missing. I understand that's covered by the 34uF cap on the crossover, which is where I stacked a 15uF and 18uF by Clarity. I might have to adjust to the new sound, but I think I preferred the open, light, more full clarity of the lows before this rebuild project.
