clairty vs sonos caps
soundfreak1
Opinions welcome as to sonos vs clairity caps for pair of rta12c's.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
Do you mean Clarity and Sonicaps?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
you cannot go wrong with either. So let price and availability be your guide.
Just found madisound is having a close out on clairty SA caps (40% off) sooooooo. Claitry SA's will do just fine!.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Go for them!!!!they are very good caps!soundfreak1 wrote: »Just found madisound is having a close out on clairty SA caps (40% off) sooooooo. Claitry SA's will do just fine!.Make it simple...Make it better! -
Also, diycable.com is going out of business and have some Carity and Erse caps on closeout.
http://www.diycable.com/main/default.php2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
is the claritycap blowout listed somewhere on madisound's website?
canadianicon25 wrote: »is the claritycap blowout listed somewhere on madisound's website?
There's a link at the top of the cap page (looks out of place). They're for the high-voltage caps, which are large. I don't regret getting my SoniCaps.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
The closeout is on the SA'S and ERSA 600+ Volts only.canadianicon25 wrote: »is the claritycap blowout listed somewhere on madisound's website?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Picked up all caps ( clairty SA ) for the rta12c's for 336.88 from. Madisound at 40% off. Now, wire, terminators, risistors, t-nuts, ect, ect.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
If you got enough to do both the upper and lower Xovers you made out like a bandit!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Looks like Madisound is clearing out its MR's.
drumminman wrote: »If you got enough to do both the upper and lower Xovers you made out like a bandit!
Got them all:
8x 25uf
8x 2.2uf fof the 27uf's
8x 2.2uf. For the 4.4's
2x 50uf
2x 4.7's for the 55uf's
All for 336.86Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I'll presume that is suppose to be 2.7uF and not 27uF. Your value choice is minus 18% out of spec and you will hear that.4.7's for the 55uf's
Again, I'll presume that is suppose to be 5.5uF and not 55uF. Your value choice is minus 14% out of spec and you will hear that too.Political Correctness'.........defined
President of Club Polk -
No... 25uf and 2.2 will give me 27.2 for the 27 uf caps
The 50 uf and the 4,7 for the 55uf
8x 2.2 will give me the 4x 4.4ufMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
yup. parallel wiring.
2.2 X 2 is fine, but 25 +2.2 and 50 + 4.7 really isn't the best way to parallel caps. A 12 and a 15, would have been better, and a 25 and 30 for the other. Always try to keep the values close when making up an odd size.soundfreak1 wrote: »No... 25uf and 2.2 will give me 27.2 for the 27 uf caps
8x 2.2 will give me the 4x 4.4ufHome Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »2.2 X 2 is fine, but 25 +2.2 and 50 + 4.7 really isn't the best way to parallel caps. A 12 and a 15, would have been better, and a 25 and 30 for the other. Always try to keep the values close when making up an odd size.
I will try this again, i need 8x 27. uf caps
4x 4.4 uf caps
2x55uf caps.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I didn't want to say anything because he was after a good deal on the caps, but I agree. I actually paid (Sonic Craft) a little extra get a 34 uF cap instead of putting 2x17 uF in parallel, and I'm really glad I did because it would have been difficult to fit them on the board (it was hard enough to fit the one).Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Ah my mistake, sorry.
However, westmassguy is right. By using small values with much larger values the small value cap acts as a bypass cap, which will impart unwanted artifacts to the sound.Political Correctness'.........defined
I see you went with the Clarity SA. The sale has me considering modding the maple LSi9s I have. Any thoughts on the ESA vs SA with the sale pricing?
cincycat13 wrote: »I see you went with the Clarity SA. The sale has me considering modding the maple LSi9s I have. Any thoughts on the ESA vs SA with the sale pricing?
Im not sure of the diff. myself. Went with tje SA'S due to past experience with them and the 40% off sure helped as well! Saved about 150.00 on the order ( RTA'S have 14 caps in them! )Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
40% off doesn't mean squat when you don't get the right stuff.....just saying.Political Correctness'.........defined
I have, on occasion, disagreed strenuously with F1nut.40% off doesn't mean squat when you don't get the right stuff.....just saying.
In this case, he's ABSOLUTELY CORRECT. -
Ok doea this sound better:
Esa 33 & Esav22 fir the 55 cap
Esa 2.2 + Esa 2.2 for the 4.4
And in yhe Esa line they have the 27 uf for the rest.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Yes, much better.
Ok order corrected. Thanks. Also have the hurricane nuts ( no spikes on them) and neutrik connectors for the connector between upper xover and lower one.mills risistors new 5 way binding posts gold slip on terminators. After that new grill cloth all around and spikes for the risors.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
You're gonna love 'em when you get the mods done."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Not to beat a dead horse, but you could have used 2 x 27uf for the 55ufs. That would have put you within 2% of the original spec.soundfreak1 wrote: »Ok doea this sound better:
And in yhe Esa line they have the 27 uf for the rest.Home Theater/2 Channel:
