Standoffs-steel vs plastic
jimbo1421
jimbo1421 Posts: 772
edited December 2011 in Vintage Speakers
Hello everyone,
I am doing some repairs on my recently acquired CRS+. They seem to have had a rough life. At some point a crossover circuit board broke loose from the nylon snap in standoffs which attach it to the big coil (inductor?). Is there any reason not to replace the nylon standoffs with steel ones? The screw heads would be quite close to the winding. The standoffs on the intact crossover are a bit loose and might rattle, so I thought a tightly screwed down circuit board would be better. Sound OK?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
    F1nut Posts: 51,798
    Buy some nylon standoffs that attach with screws at each end. Mouser and Digi-key sell tham. Do not use metal ones.
  • jimbo1421
    Thanks, F1. Is this due to some kind of electromagnetic interference?
    I found nylon ones at Digi-Key. Should I also use nylon screws?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 51,798
    It's possible, so best to avoid that possibility.
    Either all nylon or the metal screws encased in nylon.
  • jimbo1421
    I found these at Digi-Key:
    http://search.digikey.com/us/en/products/NY%20PMS%20632%200038%20PH/H556-ND/46317
    http://search.digikey.com/us/en/products/1903C/1903CK-ND/61882
    They look like they will work if I can't find something local.
    Another question occurred to me: The nut inside the big coil which receives the large bolt that attaches the crossover to the cabinet was just stuck on with hot melt glue. It popped off. I replaced it with a tee nut, fastened with small screws. Any problem with that?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • StantonZ
    StantonZ Posts: 452
    I use something that used to be called "tip toes" for ALL my Monitor 10's (3 per speaker); they are basically solid metal/aluminum. Results in a clean+tight bass.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
    F1nut Posts: 51,798
    jimbo1421, these are what some of us use.
    Mouser part numbers;
    561-R832.375
    561-MF832-75
    561-H832
    651-08032
    Probably not, they are further away from the coil than some of the screws would be on the board.
    F1nut Posts: 51,798
    StantonZ wrote: »
    We're talking about standoffs for a crossover board, not speaker spikes.
  • gimpod
    gimpod Posts: 1,793
    If spikes work for speakers why wouldn't they work for a crossover. :razz:
  • inspiredsports
    inspiredsports Posts: 5,502
    Ferrous metals and inductors don't mix well. I would stick with nylon.
    However, as a 2012 project, I 've just purchased a second set of 2B crossovers that I indend to modify into external crossovers mounted in a wooden case. I will probably experiment with elevating the cases on spikes.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,798
    gimpod wrote: »
    Hehe.....
  • jimbo1421
    Thanks, F1. I found nylon standoffs and screws locally. Everything is back together now and in my rig. See http://www.polkaudio.com/forums/showthread.php?127953-SDA-1b-vs-CRS.
    The next job is to come up with a good interconnect cable/jack. I just stuck an RCA plug into the pin hole, but it is a loose fit.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
