I want to build some stands for lsi9's
Flash!
Flash! Posts: 28
edited February 2009 in DIY, Mods & Tweaks
I am planning on building some heavy duty stand for the LSI9's. I plan on using 2 2x4's for each stand. For the top and bottom i would like to use thick plywood as opposed to that particle board stuff i can't recall what it is called. MSF i think. I would like to also have sides (maybe 3 to 4 inches high) for the top to make them even more resistant to being knocked off. These stands will be screwed down to the stage of my home theater. I am concerned that they will be knocked down by my 3 yr old and her 3yr old cousin. Has anyone screwed down their stands to the floor. Will this be acoustically a bad idea.
Post edited by Flash! on
  • ShinAce
    ShinAce Posts: 1,194
    When I use a tuning fork to tune my guitar, I ping it and then rest the bottom of it(the stand part, really) on a surface to make it louder.
    Bolting stands to the floor will change how bass travels, since now the floor will act a bit like a speaker. It can be good, it can be bad. But hey, it's a few bolts at the end of the day.
    Stands should be stiff, and if possible, heavy. Fill them suckers with sand.
  • Flash!
    Flash! Posts: 28
    Gotcha! I guess the good thing i have going for me is that the stage will be filled with sand, so that it deadens the sound as soon as the vibration travels through the stands. I am going to try and make them as heavy as possible.
  • tryrrthg
    tryrrthg Posts: 1,896
    Use MDF for the top and bottom plates. MDF is more inert than plywood. You could make the top and bottom plates 1.5 inches thick.
    I built some stands based on the design below, only I used two 4 inch PVC posts per stand.
    http://www.tnt-audio.com/clinica/stubby_e.html
    as for keeping the speakers from being knocked off the stand just buy some blu-tak. it is reusable poster putty adhesive that will hold them down nice and tight and won't damage your speakers
  • Ender
    Ender Posts: 603
    tryrrthg wrote: »
    I really like this simple, yet effective design... but I don't really understand the part on how to attach the PVC to the two pieces of wood on either side.
    Also, is blu-tak really enough to keep such heavy things like speakers on their respective stands (my goal is to purchase either a LSi9 or CMT-340SE... probably the CMT cuz it's cheaper)?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • tryrrthg
    Ender wrote: »
    The threaded rod sandwiches everything together. You're basically putting a big long bolt between the two pieces of wood and through the PVC. here is my old build page with some pictures.
    http://www.angelfire.com/alt/tryrrthg/DIY/DIYstands.html
    The blu-tak will hold PLENTY strong. it is a bit of work to get the stuff to let go of your speakers. If someone were to bump into my speakers the stands would fall over before the blu-tak would let go of the speakers.
