Klipsch Sub-12 compared to $$$
Ethancf
Ethancf Posts: 478
So I have a Klipsch Sub-12 that has performed and integrated into my system very well...had it for a couple of years. It's in that sub-$500 category. When jumping into the $1000+ range, what do you gain? I've seen similarly powered / driver size subs close to 2 grand? Is it just a matter of frequency range? When it comes to subs, I think placement and sound dampening can make all the difference in the world vs. throwing money at a new sub.
Velodyne is tempting me, but I'm just curious what the return would be.
Thanks!
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited February 2009
    EthanCF,
    I don't own any of the $1000 subs so it's hard for me to comment on their performance compared to the Sub-12. I do own a Sub-12 however, so I can tell you how it compares to some to the other subs I've owned.
    To me the Sub-12 is a very good home theater sub. It goes down pretty low and is loud. To me, and with my setup however, I didn't find it to be a good sub for music. It didn't blend with my other speakers very well no matter how much I tinkered with the volume and cross-over settings. I find the bass to be a little muddy with music also. I have replaced it in my main system with a Polk DSW Pro 600 and I like that sub much better ( I am now running two 600s in my main system). The 600 doesn't reach down quite as low as the Sub-12, but it's close. It is a much better sub for music however. It is much smoother and detailed and to me is just a better all around sub. Of course that's just my opion, YMMV.
  • goingganzo
    goingganzo Posts: 2,793
    in the sub 1k range svs is hard to beat over 1k diy is king. rember the bigger the driver the more bass you get.
    lets say you order 4 of there at $200 each https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=15495fe3b15ab9c/shopdata/0050_Speakers/0050_IB3/product_overview.shopscript
    and 1 of these for $700 http://www.guitarcenter.com/Crown-XTi-2000-Power-Amplifier-103635579-i1145685.gc
    suply costs 1-2 sheets of mdfbcut to 24 in $50-60 some 2x4 and paint 20 bucks.
    for $1600 you can be above 110 db under 15 hz. with olny a few store bought subs can do and you would need to pay more than 10k for them
  • Retro152
    Retro152 Posts: 985
    Dawgfish wrote: »
    EthanCF,
    Im also currently running the Sub-12, and Dawgfish is right on the money. The Sub-12 is very good for home theater, but lacking for music. Having the same trouble trying to tweak the sub and speakers. I am thinking of Svs or Velodyne for an upgrade.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • Sherardp
    Sherardp Posts: 8,038
    I started out with dual subs, one being a Yamaha ****( dont remember model) and a Klipsch KSW 12. When I joined the forum I started out with that, when buying the Polk Setup, SVS was mentioned to me. Having no idea what the heck to expect I bought the PB12/Plus 2. It arrived and it was much improvement over both subs, more articulate, not boomy bass but good bass you can appreciate in quality sound. I sold both the Yammy and Klipsch subs, 3 months later I ordered a 2nd SVS sub of the same model and paired them up with a Velodyne SMS-1 for even better SQ. So you can gain allot, you get what you pay for, as the saying goes.
    If SVS makes a dual driver PB13U I'm definitely in.
    Got to go with the majority here.
    The SUB-12 is a good sub in that range, especially for movies. On music, not so much.
    Among other things I own the Boston Acoustics HPS-12HO whose specs are pretty close to the Klipsch and has similar power ratings but weighs about 5-6 pounds more and has a less resonant though smaller cabinet.
    I'd say the two, again IMO, compare favorably on Movies, they retail for about the same. The B.A. seems a bit tighter to me on music than the Klipsch. The Klipsch is less fussy regarding placement.
    What you get for over 1000 dollars is 1000 watt plus class D amps--so a bit more volume, lower frequencies--often subsonic (lower than 20hz) that you feel rather than hear. I should add that those frequencies including the ones below 25 hz that the B.A. and Klipsch have trouble with are not as loud as the tones 30hz and above even on the superbad subs...if you look at the test graphs you'll rarely see those subs getting above 95-100db at 20hz or below? 100db is actually a tad optimistic. Because it takes FANTASTIC power to reproduce those frequencies at very LOUD volumes!
    But that is made up for by the sound pressure that your body experiences.
    I'd say audition a few and see what you think. My opinion the guys that are running four or more 2000+ dollar subs in their 20X20' room are nuts! There's something wrong there!
    cnh
  • curved
    curved Posts: 664
    They are a lot more musical......not all are 1000watt Class D amps.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
    nooshinjohn Posts: 26,062
    i like my sub-12 with music but I turn the volume down a bit and and adjust the cross to about 100 or there abouts and it sounds great...
