Polk SDA SRS 2 Vintage Oak Speakers - $495 (Tucson)
BIZILL
BIZILL Posts: 5,432
edited February 2009 in Vintage Speakers
http://tucson.craigslist.org/ele/1007574777.html
good price? no, they are not mine. just wondering if this is a good deal or not.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360
WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.php
bobman1235 wrote:
I have no facts to back that up, but I never let facts get in the way of my arguments.
Post edited by BIZILL on
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2009
    not sure i want to spend any dough right now, but being offered in your own city makes it hard to resist.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2009
    I have this model (Blade/Blade), but everything I have ever seen about it shows it as a 1986. The speaker was then upgraded in 1987 to use the SW155 (instead of SW150 in 1986) passive radiator, to use half and half 6510/6511 mid-woofers (instead of 6509's in '86), and a more modern crossover network with Pin/Blade. The 1986 crossover is also in 2 parts and has HUGE low pass cap values requiring off board location if you upgrade. IC connection is also separate hole through cabinet. 1986 is 4 ohm. 1987 improved is I believe 6 ohm. There was even a rare latest version that was bi-ampable, but most were not.
    The fact the seller states he bought them in 1985 is confusing. I paid $450 Philadelphia last November and have dropped about 1K in mods into them, $400 of that in 4 new 6509's and 4 new RDO194-1's.
    The 2.3TL is clearly the best sounding of the SDA SRS 2 series. Mine are darn nice now, but the RDO194-1 (SL2000) replacement will never outshine the RDO198-1.
    Here's lots of info: http://www.polkaudio.com/forums/showthread.php?t=74946
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2009
    that's why i came here...
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • bluecomet
    bluecomet Posts: 1,118
    edited January 2009
    I paid more for mine but it was a local pickup so it was worth it to me. No shipping involved. There are two kind of SDA SRS 2 speakers. There is the blade/blade type that is a 4 ohm speaker and then there is the pin/blade type that is bi-ampable and is 8 ohm. I have both. Make sure what kind of equipment you want to use with them. You are going to need a receiver or amp that can handle the 4 ohm SDA SRS 2's. Both are going to need power in the range of 200 watt a chanel to get them to really sing. Either way $495.00 is a good deal if that is the speaker you want in excellent condition, plus it has the interconnect cable which is a plus. Good luck.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • inspiredsports
    edited January 2009
    bluecomet wrote: »
    Yours were the "Best of the bunch for this series" before 2.3 and 2.3TL. (Woo-hoo; 400th post!)
    NAD SS rigs w/mods
    GIK panels
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2009
    SRS SDA 2= a lota speaker for 5 bills...My first SDA speaker,wish I had em' back.
    I liked their sound over the 2.3TL's that I had...the 2's are very easy to drive and easy to listen to .
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2009
    If they are as stated, in pristine condition, it sounds like a great local deal to me. I'd at least take a look. From what I've read here, better than the 1Cs and some prefer them to the 2.3(tl)s.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Cardinals-1
    Cardinals-1 Posts: 80
    edited January 2009
    The SRS 2 weighs more than 65 lbs.
    I would ask ffor pictures.
  • inspiredsports
    edited January 2009
    1986 SDA SRS 2's weigh 135 lbs each, but by driver description and dimensions shown they are absolutely 1986 SDS SRS 2's
    Hmmm . . . he bought them a year before they were produced and only half of them at a time . . . :)
    NAD SS rigs w/mods
    GIK panels
  • Ron Temple
    edited January 2009
    If you look at the ad description...2 tweeters, 4 mw's and a 15" passive...these are SRS2s and he's got the rest of it wrong.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bluecomet
    edited January 2009
    When I bought both sets of SDA SRS 2's locally from the same guy, I had to have the previous owner with a hand truck help me. It took me and the other guy to pick up the speaker and gently place it in the back of my jeep laying them down. They are easily 135 lbs. a piece. The SDA SRS big boy must really be a beast. You need a big room for either the SDA SRS 2 or the SDA SRS speakers for these bad boys to breathe. The SDA 1C's are a good choice for a normal room. They have plenty of power and sound great and can be moved much easier by yourself. The SDA 1C's do not have the bass of a SDA SRS 2 nor can they handle the input power from amps like a SRS 2 can. They are rated at 750 watts. If you have the room for these speakers you can't go wrong.
  • BIZILL
    BIZILL Posts: 5,432
    so am i mistaken or did this fella list this wrong? i have the 1.2tl's already, i just happened upon this whilst up in some craigslist action and thought i'd ask here or at least help dude out with some potention buyer viewage. either way, i think i'll pass...
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • I-SIG
    I-SIG Posts: 2,243
    Saw these too. If they are blade/blade then there's no point in me even looking since I have the original SRS. I'm not saying that the SRS 2's are inferior, just that if I can't eventually bi-amp them horizontally, then what's the point for me, especially with som epin/blade 1C Studio's laying around.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • BIZILL
    BIZILL Posts: 5,432
    ever get those 1c's taken care of wes?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • inspiredsports
    I-SIG wrote: »
    Saw these too. If they are blade/blade then there's no point in me even looking since I have the original SRS. I'm not saying that the SRS 2's are inferior, just that if I can't eventually bi-amp them horizontally, then what's the point for me, especially with some pin/blade 1C Studio's laying around.
    Wes
    After having them completely apart for rebuild and noting the 1986 version has 2 separate (low pass and high pass) crossover circuit boards, I had the thought of bi-amping. Just a single black and white wire connects the 2 boards. I'm not sure how the SDA effect comes into play, but someone in the group may be able to come up with a circuit topography to make this possible.
    The tweak that I think would really make the SDA SRS 2 shine (and make it a truly sought after model) would be a crossover mod to allow for the use of the RDO198-1. That's over my pay grade, but having TL'd my 2B's, and now listened to both the SRS 2 and 2B's for over 300 hours each, I KNOW the SDA SRS 2 would become a top speaker with just a few more natural db's in the 6K to 12K range.
    I think it might be a relatively complicated math problem moving from the 4 ohm RDO194-1 to the higher impedance 198.
    NAD SS rigs w/mods
    GIK panels
  • bluecomet
    I have the SRS 2 bi-ampable version. The speakers are 8 ohms. Do you think I could just drop in the RDO 198 tweeters. Is that possible.
  • Mike Reeter
    bluecomet wrote: »
    I think the tweeter you want is the RDO 194...that's the replacement for the original SL2000
    And yes,you can just drop in new tweeters,they are a great improvement over the 2000's
  • bluecomet
    I know the RDO 194 are replacements for the SL2000's. They are a nice improvement. I did the swap on my SDA 2B's. I was just wondering if it is possible to use a RDO 198 tweeter instead. The previous post seemed like the 4 ohm SRS 2 made it a problem to upgrade to a RDO 198. Since my version is the 8 ohm SRS 2, I wondered if a conversion to a RDO 198 could be possible without modification.
  • inspiredsports
    Lasareath wrote: »
    No, You'll need to modify the crossover to use RD0198-1's
    Exactly, and that's where I said it was "above my pay grade".
    Even though my speakers1986 SRS 2 are 4 ohm, and bluecomet's are the latest of that series and 8 ohm bi-ampable, the crossover components are what determine the end result which is the use of the RDO194-1.
    Someone with a good working knowledge of the impedance, resistance and inductance through the entire circuit would need to determine what combination of capacitor, resistor and inductor would have to be in place to move from the 194 to 198. I'm guessing his and my speakers would require slightly different mods.
    My point was that if someone could spec out the changes, I'm positive it would be an improvement. I'm listening to the 198's in my 2B's right next to the 194's in my SRS 2's on a daily basis and the 198's win hands down. The 194's come close when I boost the 6 Khz signal from the preamp by 5 to 6db.
    F1 describe the sound of the RDO194-1 as "hollow", and without the 6db boost I'm able to add, I agree.
    I know people contacted Ken S. and others at Polk to effect the SDA-2B "TL" mod, and I guess that's what I'm proposing here. The problem is that I'm not an EE and I'm not sure I would understand the steps need to reach the solution.
    NAD SS rigs w/mods
    GIK panels
  • bluecomet
    Well, that answered my question. I could live with RDO 194 replacements. These speakers in my opinion sound much better using a EQ. I used my old Sherwood 12 band EQ and the SRS 2's came alive plus you can tailor the sound much better. You might like what you hear.
