found a set of silver7t's
nooshinjohn
I found a set of Carver silver 7t's that I may be able to get for about 650.00...... I am trying to get the owner to sell them separately from his martin logan requests. If someone will by the M/L's he will let me get them but wants to sell his audio set complete and I will know on monday if they are mine... would these be ok with my sda-1c's or overkill.
Post edited by nooshinjohn on
I'm pretty sure you can strap the neg terminals on those monos and they are very nice amps. Might want to ask on the Carver site if someone doesn't post here. Overkill, probably not, and $650 is a very good price.nooshinjohn wrote: »I found a set of Carver silver 7t's that I may be able to get for about 650.00...... I am trying to get the owner to sell them separately from his martin logan requests. If someone will by the M/L's he will let me get them but wants to sell his audio set complete and I will know on monday if they are mine... would these be ok with my sda-1c's or overkill.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Be sure you can strap them or you need a AI-1 cable variety.
Also be aware only certain serial number 1C's can use the AI-1; if you have the compendium it tells you, if not, when I get home I'll look your serial #'s up if you provide them.
Not overkill by any means.......no such thing:D
Awesome Find. Where is the Martin Logan at and how much he wants for it? Does he has Original Box to ship or just for local sale only?
Silver 7t are a rare find so don't let it pass up on you.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
the logans are in denver colorado I guess he would take 1500 for the pair but he does not have boxes so packing and shipping would be on the new owner...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I think the logans are not priced too bad either. But without the box, I think it's very risky to get these shipped.
If the boxes were to order from ML, I think they cost between 150-200 so plus shipping is not worth it. I found a pair of ML in Sacremento area for less. Well, good luck with your hunt on the 7Ts. If I were you, I would tempted him by offering more and get these coz I saw them usually go for more than 1000+ region for a good working pair.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I am tempted to do the same, but am already ouside the budget at 650The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
You're not likely to get a TFM 55 for much less than $550-$600, but if you can, then it's plenty for the 1Cs too. I can't touch the headroom on the TFM 45 with my mine.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
That's less than half of the cheapest price I've seen 7t's go for lately....TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer
