SDA-1C imaging update
nooshinjohn
nooshinjohn Posts: 25,926
edited January 2009 in Vintage Speakers
welll i found the root cause of the trouble to be a poorly made shield connection. I corrected it and in doing so induced a far worse problem. I am running a Yamaha rx-v861 currently and what happens is the receiver goes into protect mode and shuts down when the i/c is made and volume is set to moderate levels. Without the i/c all is great. any ideas...:confused::confused:
Post edited by nooshinjohn on
  • Face
    Face Posts: 14,340
    edited January 2009
    It appears your Yammy isn't common ground.
    Time to man up and get a real amp.
    treitz3 Posts: 19,992
    edited January 2009
    I thought he had another issue as well. Here's a quote from another thread.
    I checked the speakers travel and hold times by pressing on the passive radiator and found that the right does not stay extended as long as left, and that neither speaker seems to hold the extended position very long... also there seems to be a metallic clanking sound from the left passive
    So, a bad driver and a possible leak in the right speaker cabinet combined with an incompatible [non common ground] amp? Yeah, that would definitely cause imaging issues.
    edited January 2009
    the left passive radiator is not a problem any longer as this has been corrected as well. Imaging has also been solved and they sound great... just cannot turn them up very loud
    I thought Yamahas were all common grounding amps... is there a way to find out if it is or not?
    edited January 2009
    I have also replaced all the seals on the speakers with mortite
    edited January 2009
    ...is there a way to find out if it is or not?
    There is an easy way to tell if any amp is a common ground amp. Take an ohm meter [or DVM] and measure the resistance between both negative speaker terminals. If it reads zero ohms, you have a common ground amp. If resistance is infinite or open, you do not have a common ground.
    The fact that all is well without the IC cable but the amp goes into protect mode when it is installed leads me to believe that your amp is NOT common ground.
  • strider
    strider Posts: 2,568
    edited January 2009
    Got a multimeter?
    Set it to ohms, burn some incense, power down the amp, strike the fragile lotus position, jam a probe into each negative binding post on the back o' the amp. If it shows zero ohms, or any small value, it's common ground. If there's no common ground, it'll show open (display shows --- on mine).
    Wristwatch--->Crisco
  • strider
    edited January 2009
    Drats, foiled again.
    My way's better, though.
    edited January 2009
    One more thing to add. Sorry, I forgot. You can run the speaker all day long wothout the IC cable hooked up with no damage to anything. That said, you will be missing the SDA effect which is what makes an SDA, well an SDA. It is not recommended to run with the IC cable on a non-common ground amp due to the possibility of damage to both the speakers and the amp.
    edited January 2009
    i get .6 when i test as you described...
  • Face
    Face Posts: 14,340
    edited January 2009
    Now stick your tongue across the negative terminals and see what happens.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    OK you can turn it up withouth the SDA IC in place?
    Ben
    edited January 2009
    :Dlol... Is it possible that having one of the speakers out of phase would cause instability in the receiver?
  • ben62670
    edited January 2009
    ben62670 wrote: »
    can you?
    Edit.
    Did you have a speaker wired wrong?
    Ben
  • Face
    Face Posts: 14,340
    edited January 2009
    With the SDA I/C in place, I believe so.
  • ben62670
    edited January 2009
    It would be around a 1ohm load that way:eek: Even without the IC in place.
    Ben
    edited January 2009
    :D:D:D:D:D:D:D:D!!!!HEAVEN HAS BEEN FOUND!!!!:D:D:D:D:D:D:D
    The right channel was out of phase even though that nasty YPAO said it was good.... and i will need better power soon as i have a driver clipping on the right so i backed it down a bit and all is well...
    You guys ROCK!!! this forum ROCKS!!! and SDA just plain kicks f@#!*%$ AS!
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:
  • ben62670
    edited January 2009
    So are you say you are happy now:confused:
    :D
    Ben
    edited January 2009
    Daggum, someone just found bliss. :cool:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2009
    strider wrote: »
    Got a multimeter?
    I especially like the part about jamming a probe into the post. Your on your way Ben.
    RT1
