SDA-1C imaging update
nooshinjohn
welll i found the root cause of the trouble to be a poorly made shield connection. I corrected it and in doing so induced a far worse problem. I am running a Yamaha rx-v861 currently and what happens is the receiver goes into protect mode and shuts down when the i/c is made and volume is set to moderate levels. Without the i/c all is great. any ideas...
Post edited by nooshinjohn on
It appears your Yammy isn't common ground.
Time to man up and get a real amp."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I thought he had another issue as well. Here's a quote from another thread.nooshinjohn wrote: »I checked the speakers travel and hold times by pressing on the passive radiator and found that the right does not stay extended as long as left, and that neither speaker seems to hold the extended position very long... also there seems to be a metallic clanking sound from the left passive
So, a bad driver and a possible leak in the right speaker cabinet combined with an incompatible [non common ground] amp? Yeah, that would definitely cause imaging issues.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
the left passive radiator is not a problem any longer as this has been corrected as well. Imaging has also been solved and they sound great... just cannot turn them up very loud
I thought Yamahas were all common grounding amps... is there a way to find out if it is or not?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have also replaced all the seals on the speakers with mortiteThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
There is an easy way to tell if any amp is a common ground amp. Take an ohm meter [or DVM] and measure the resistance between both negative speaker terminals. If it reads zero ohms, you have a common ground amp. If resistance is infinite or open, you do not have a common ground.nooshinjohn wrote: »...is there a way to find out if it is or not?
The fact that all is well without the IC cable but the amp goes into protect mode when it is installed leads me to believe that your amp is NOT common ground.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
nooshinjohn wrote: »the left passive radiator is not a problem any longer as this has been corrected as well. Imaging has also been solved and they sound great... just cannot turn them up very loud
Got a multimeter?
Set it to ohms, burn some incense, power down the amp, strike the fragile lotus position, jam a probe into each negative binding post on the back o' the amp. If it shows zero ohms, or any small value, it's common ground. If there's no common ground, it'll show open (display shows --- on mine).Wristwatch--->Crisco -
Drats, foiled again.
My way's better, though.Wristwatch--->Crisco -
One more thing to add. Sorry, I forgot. You can run the speaker all day long wothout the IC cable hooked up with no damage to anything. That said, you will be missing the SDA effect which is what makes an SDA, well an SDA. It is not recommended to run with the IC cable on a non-common ground amp due to the possibility of damage to both the speakers and the amp.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
i get .6 when i test as you described...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Now stick your tongue across the negative terminals and see what happens."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
OK you can turn it up withouth the SDA IC in place?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
:Dlol... Is it possible that having one of the speakers out of phase would cause instability in the receiver?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
can you?
Edit.
Did you have a speaker wired wrong?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
nooshinjohn wrote: »:Dlol... Is it possible that having one of the speakers out of phase would cause instability in the receiver?
With the SDA I/C in place, I believe so."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It would be around a 1ohm load that way:eek: Even without the IC in place.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
:D:D:D:D:D:D:D!!!!HEAVEN HAS BEEN FOUND!!!!:D:D:D:D:D:D:D
The right channel was out of phase even though that nasty YPAO said it was good.... and i will need better power soon as i have a driver clipping on the right so i backed it down a bit and all is well...
You guys ROCK!!! this forum ROCKS!!! and SDA just plain kicks f@#!*%$ AS!
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D: The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
So are you say you are happy now
Ben -
Daggum, someone just found bliss. :cool:~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Got a multimeter?
I especially like the part about jamming a probe into the post. Your on your way Ben.
RT1
