Proud owner of Monitor 10 speakers
jlewand
jlewand Posts: 5
edited February 2009 in Vintage Speakers
Bought in 1988. Every time someone hears them, they always say how sensational they sound.
Anyway, I always thougth I had 10B's, but serial # tag on back says:
10 195104
I have literature that shows the Monitor series including the 10B. I also have printed off the Monitor 10 info from polk's website.
10B shows 2000 tweeter, while the 10 liberature shows SL2500.
Can anyone say for sure which I have? I assume 10 since serial # plate says 10.
I've read up on here about replacing caps (capacitors?) and other things. How much change might this make for my speakers? They are in excellent condition and have always been on the first floor (not hiding in the basement).
Recommendations?
Thanks.
J
Post edited by jlewand on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Welcome to Club Polk. Can you post a pic of the tweeters? That would help a lot. Also is there a fuse on the back? The cap/resistor upgrade is definitely worth while. Let us know where you are. There may be a Polkie near by that could help with the XO upgrade.
    Ben
    Ben
  • jlewand
    jlewand Posts: 5
    edited January 2009
    I'm in the Chicago area.
    All black tweeter. Says:
    Polk Audio
    Silver Coil dome
    I do NOT see a tiny pinhole in center of the tweeter.
    Looks like the typical tweeter seen in the 10B and 10 documentation I have.
  • ben62670
    edited January 2009
    If the tweeter is all black then it shouldn't say silver coil on it. Can you pull it and see if it says SL2000 on it?
    Ben
  • tx_polkhead
    tx_polkhead Posts: 248
    edited January 2009
    Silver Coil Dome is the SL2000.
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • Flash21
    Flash21 Posts: 316
    edited January 2009
    My Monitor 10Bs were bought in 1985...I still have the receipt. But the tweeters were translucent-dome SL2000s.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • LCruiser122
    LCruiser122 Posts: 23
    edited January 2009
    This has me curious too.
    My 10A s do have a fuse on the back. (bought around '80)
    I recently replaced my tweeters (from Polk)
    I replaced one tweeter 20 years ago so I had two different tweeters.
    1 is all black with pinhole in center. A white sticker says made in USA
    2nd tweeter is silver with clear dome.... says SL1000 7/22/88
    Any idea what the black one is?
    Also, is it wise an what should I do for XO upgrade?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,205
    edited January 2009
    "Any idea what the black one is?"
    Peerless tweeter.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • LCruiser122
    edited January 2009
    Peerless tweeter.
    really ?
  • michaeljhsda2
    edited January 2009
    "I do NOT see a tiny pinhole in center of the tweeter."
    Nevermind, my bad.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jlewand
    jlewand Posts: 5
    edited January 2009
    The back of my speakers simply has the red/black posts for wire connection. No fuse or anything of any kind.
    By all-black tweeters I mean the metal part is all black. The tweeter itself is that "dirty celophane" color.
    The thumbnail posted is definitely NOT mine as it's all black (including the tweeter dome) and has the pinhole.
  • ben62670
    edited January 2009
    You have the SL2000. You should get the RDO-194 from Polk. There are plenty of threads showing the XO upgrades. Let us know when you are ready.
    Ben
    Ben
  • jlewand
    jlewand Posts: 5
    edited January 2009
    Since my serial #tag has "10", are mine Monitor 10's vs. 10B's?
    Also, the 2 docs I have show 6 ohm or 8 ohm. Which are they? (AV receiver wants to know).
  • ben62670
    edited January 2009
    6ohms nominal. If you have to choose between 4 and 8 choose 4.None were really 8ohm. A lot of vintage Polk's were listed as 8ohm compatible, but were actually 6, and would dip to 4 or below at certain frequencies.
    Ben
    Ben
  • Big Dawg
    Big Dawg Posts: 2,005
    I just picked up a pair of 10Bs at the local Goodwill ($50, cabinets a little scuffed, drivers clean and sound GREAT). I'm curious - they seem to have the SL1000 tweeters (brushed aluminum), but have fuses in the back. I thought that only the peerless have fuses - am I mistaken about that?
