SDA-1C Imaging troubles
nooshinjohn
nooshinjohn Posts: 25,928
edited January 2009 in Vintage Speakers
hi guys...
with all the excitement of getting these in my home and reconditioning them, I have noticed that the 'sweet spot' for listening to them appears to occur to the right side of center. When sitting between the speakers most of a performance comes from the left side. My receiver's balance is properly set, both speakers are wired properly and are in correct phase. my interconnect was replaced by and rca jack on both speaker and is connected. I can hear a difference in sound quality when it is disconnected... any ideas?
Does somebody have a copy of the owners manual for these that I could get a copy of?
thanks guys for the help:cool:
Post edited by nooshinjohn on
  • danger boy
    danger boy Posts: 15,722
    edited January 2009
    just for **** and giggles.. swap the two speakers around... left on right, right on left.. and take another listen.. it's rare, but sometimes people have ended up with two lefts, or two rights.
    also sounds like one of your mid driver ain't working. it's tough to tell because even with the interconnect cable unplugged.. they still appear to be working. to be sure. take each driver out one at a time. and connect it to speaker wire with a low volume music.. and see if each one is working properly.
    good luck though.
    PolkFest 2012, who's going>?
    edited January 2009
    tried that and got no sda effect at all
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    Did you move the chair that was in front of one of the speakers? That could contribute to that a little bit...just an idea though. That probably isn't the problem, and I'm sure you already tried it.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    It's your room. You need to move closer to your speakers. If your speakers are 6 feet apart your head should be no more than 8 feet back. Also you should have 3 feet on either side minimum. Room treatments can help a lot. You want to add panels at the first reflection. I've tried to put 10lbs in a 5lb bag. It doesn't work:(
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2009
    sorry for the thread jack, you guys would hate me. mine are 4" off the side walls and about 12" off the back wall. They are about 10' apart, and my listening position is about 10' back. room gain picks up below 40Hz, so my little sda2s do just fine in the low bass region, and imaging is till nice and tight.
  • dudeinaroom
    edited January 2009
    what other gear are you running with your sdas
  • Marty913
    Marty913 Posts: 760
    edited January 2009
    Try everything else suggested and if you still want the manual I have one. It's actually an addendum to the 1B manual with technical spec changes. The placement options are in the 1B manual which I also can provide. Email me if you need them scanned and sent. I don't check messages that much but I'm always on email.
    Marty
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Face
    Face Posts: 14,340
    edited January 2009
  • comfortablycurt
    edited January 2009
    Face wrote: »
    Yeah...that's the chair I was talking about. If that thing is still there...get it out! That is ruining your imaging. Your sound is getting fired right into the side of that chair, and being absorbed by it.
  • Conradicles
    Conradicles Posts: 6,343
    edited January 2009
    You can also get the user manual @ http://www.polksda.com/
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2009
    I know most people don't drop $90 on something rarely used, but if you really want to eliminate guesswork, a db meter is irreplaceable. I've had great results with this one:
    http://www.amazon.com/exec/obidos/ASIN/B000EWY67W/websitementcommu
    A calibrated Test CD with left and right test, dog barking, phase tests, pink noise, tones, etc. is also helpful. I got one of these free in 1990 when I subscribed to "Stereophile" magazine and use it every time I buy, tweak or modify a speaker setup:
    http://www.amazon.com/exec/obidos/ASIN/B0000049XN/websitementcommu
    You can then hold the meter right in front of each driver in the system and know for sure what it is contributing to the mix. Once you prove the signal sources are equal, you can move on to room treatments.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    edited January 2009
    i did try moving the chair...that was my first thought, and did not have any effect. The imaging coming from the left speaker is stronger than the sound from the right. Both speakers are 5 inches from the back wall and 39" from the wall on the sides with 5'6" in between. My seating area is 10 feet back from the speaker... I have tried sitting closer to the speakers when listening and this did not help. Balance is set correctly between speakers and the settings on the yamaha are exactly the same for both channels. All drivers are functioning. When comparing left/right with test tones there is an audible difference in output between left and right even when my ear is placed within inches of each speaker. When the I/C is disconnected from the speakers there is no change in output. They are being listened to in pure direct mode two channel operation.
    hope the added info helps... I was thinking there may be a phase issue with internal wiring on the right side. could this be possible?
  • ben62670
    edited January 2009
    There is something wrong if you hear no difference with the IC cable disconnected.
    Ben
    edited January 2009
    by no change in output I am refering to volume only. I do here a difference in sound quality...
    the left side also seems to has a slightly deeper tone than the right, could there be a variance in the crossovers?
    edited January 2009
    ok... I have figured out that the left has about twice the output of the right side... at this point I am leaning toward either power problem or a crossover problem...
  • ben62670
    edited January 2009
    If you have a multi meter set it for ohms. With all cables disconnected you should read about 1.3 ohms from the pin hole on the IC socket to the ground. That number is a rough one. I do not have my book with me. Just as long as both are the same you are good. Also you can check from the positive to the negative, and the pin hole to the positive. Let us know the numbers you come up with.
    Ben
    Ben
    edited January 2009
    i do not have an ohm meter... but will get one tommorow
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2009
    I've gone through a similar problem. Thought it was an amp, thought it was my room, sent amp off, couldn't correct room. It was a dimensional driver that was failing. Not noticeable through any surface detection initially, but I finally put my hand in front of it and noticed it wasn't moving near as much air. I was losing about 5 dbs on the right. Replaced the driver and all was good. Recently, I'm noticing that my right is 1-3dbs down again. I'm pretty sure that it's the seals that are leaking. thsmith did the mortite treatment and it fixed his. I'm going to do that next. Anyway, I'm guessing you've got a driver that's gone or about to go.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    edited January 2009
    sounds logical... I will do the reseal on all the drivers as well
    edited January 2009
    I checked the speakers travel and hold times by pressing on the passive radiator and found that the right does not stay extended as long as left, and that neither speaker seems to hold the extended position very long... also there seems to be a metalic clanking sound from the left passive
    treitz3 Posts: 19,999
    edited January 2009
    That right there is a big problem. Replace that driver!
  • dudeinaroom
    edited January 2009
    if you have another set of speakers hook them up in there place. If both of the other speakers play at the same volume (left to right) then the problem is the SDAs. If not I would check interconnects between components. swap them out with another set and see if the problem remains.next step would be components( receiver, pre, amp and sources.
    edited January 2009
    :( ok here are the readings... for the right speaker:
    4ohm between the positive and negative terminals
    2.5 ohm negative terminal to center pin
    3.5ohm positive terminal to center pin
    0 ohm center pin to shield
    LEFT SPEAKER:
    4ohm between positive and negative terminals
    2.6 ohm negative terminal to center pin
    3.5 ohm positive terminal to center pin
    2.6 ohm center pin to shield
    I am assuming that my trouble lies within the center pin on the right speaker or within the sda driver wiring. I will be taking apart the drivers and using mortite to seal them I will also inspect the wiring...:(:confused:
  • inspiredsports
    edited January 2009
    Maybe, but let the experts weigh in. If an SDA effect driver is shorted, I'm not sure what that does to impedance.
    NAD SS rigs w/mods
    GIK panels
  • dudeinaroom
    edited January 2009
    your rca connection is grounding out some where in the signal path. look for a crossed wire, dripped solder, also check for a lose wire hitting the back of your passive radiator It may have came off one of the drivers
    edited January 2009
    this thread has been superceded by
    http://www.polkaudio.com/forums/showthread.php?t=77750
    Thank you for all the help with this one... unfortunately it created a new one... receiver has been checked and it IS a common ground design...
    lol
    thanks for the help
