Common ground amps
leroyjr1
Does anyone know if Rotel amps are common ground? Need to know how they'll work with SDA's?
Rotel
RB-1092 2 channel
RB-1080 2 channel
RMB-1075 5 channel
RMB-1095 5 channel
Rotel
RB-1092 2 channel
RB-1080 2 channel
RMB-1075 5 channel
RMB-1095 5 channel
Post edited by leroyjr1 on
Got a multimeter? Super easy to figure that out.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Doro will hopefully correct me if I'm wrong, but AFAIK...
Set the meter to check resistance, amp off, unplugged if it makes you feel more comfortable. Take off shoes and any metal jewelry.
Set the probes on each of the negative binding posts, if it's open you'll get no reading (reads - - - - on my meter) and the amps non-common ground. If you get zero or close then the amp ground is common.Wristwatch--->Crisco -
Yep, check for resistance between the negative terminals. Zero resistance is common ground.
Another way without a meter is to look at the bridging options. If the amp is bridgeable and you need to use the red terminals for the single speaker, it's common ground. -
Thanks ShinAce & strider
Will it be the same with my 5 channel amp as well? -
I add a little to this. Now if you use 2 amps in this fashion (bridged) it's acts and is non common ground.
Ok thats clear as mud.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Just an update. I emailed Rotel asking if there amps was common ground and they just got back with me .
All amps are common ground except the new class d digital amps. -
Take off shoes? And do what, stand barefoot in a pan of water? If you are trying to reduce a path to gound you need to increase your resistence, not lower it.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
LOL,, after you master this task,young Jedi,,,you will be asked to bias tubes with the power on.;)JC approves....he told me so. (F-1 nut)
