Simple wire question
dborzz
dborzz Posts: 87
New here and I already received some good advice already on speakers.....so now I need to replace the HTIB wires that I'm currently running. I don't wanna spend alot of cash until I can upgrade my system, so I have ordered some 14g from monoprice. Somewhere in these posts I read something decent about monoprice and bluejeans wire for cheaper wiring solutions until I'm ready to become one of the big boys!! I will be using this for Onkyo 606, R30 front, M30 rear, CS2, PSW111. So I hope the wires I have ordered will be ok for now. Thanks for any input on wire advice. Is 14g wire the correct size because I don't have too far to run the wire to any of the speakers?
Polk T90e's(m60)-mains
Polk CS2-center
Polk OWM3's-surrounds
Polk Micro Pro 1000-sub
PS3-blu-ray,gaming
Pioneer 43inch purevision plasma
Onkyo tx-sr606
MIT EXp 1
Post edited by dborzz on
  • kolyan2k
    kolyan2k Posts: 259
    edited January 2009
    yes. and i dont know anything about monoprice (although i am sure there is nothing wrong with them either), but bluejeans will be just fine even for "big boys" as you say.
  • Willow
    Willow Posts: 11,246
    edited January 2009
    you should and will be fine
  • dborzz
    dborzz Posts: 87
    edited January 2009
    Thanks kolyan and willow. I guess reading all these endless posts actually does help!!! lol
    I appreciate the quick response
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • Willow
    edited January 2009
    seeing as you just joined your "for now" is perfect. In a couple months of reading and participating you'll want to upgrade...you'll see
  • Cardinals-1
    Cardinals-1 Posts: 80
    edited January 2009
    Back before Monster Cable and the like people would use 12 gauge Romex with great success. It does not have all the twists per inch but a lot of copper between your amp and speakers.
  • dborzz
    dborzz Posts: 87
    edited January 2009
    Hey Willow, it's been a few days and I'm ready to upgrade...lol. I have to remember there's always the basement and bedrooms to fill with speakers!!
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
