subwoofer no sound HELP
rfp
rfp Posts: 1
I have a pioneer vsx-d409 reciever and have a
rca cable"sub pre out" (no left & right on this pre-out)
connected to the polk psw450 LFE
NOTHING COME OUT
How do you hook this thing up so that is produces sound?
H E L P
Post edited by rfp on
  • rs159
    rs159 Posts: 1,027
    edited June 2003
    Did you plug it in and turn it on? ;)
    Did you set up the bass management so your receiver knows you have a subwoofer? The manual could probably explain it a lot better than I could.
  • Alan M
    Alan M Posts: 9
    edited June 2003
    check you settings, 'lfeatt', 'lcf' etc. I have the pioneer 510 and had a similar problem, the bass was real low until I turned off all that stuff. hopefully that's all it is
  • danger boy
    danger boy Posts: 15,722
    edited June 2003
    receiver have a menu where you can turn it on or off.. i have a feeling this could be your problem. come back if you still have trouble. Be sure it's connected into the right output on your reciever.. most receivers have lots and lots of outputs.. that could be mistaken for the sub out.
    PolkFest 2012, who's going>?
