Newbie wiring question-RTi6
audiorook
I just bought a new pair of RTi6s and hooked them up to my old Rotel receiver using a single wire hookup with bare wire to the bottom speaker terminal. I just played a CD and it sounds like the tweeter is not even playing, like the sound is underwater. Pretty bad sound. Should I hookup the receiver to the top speaker terminal instead? What am I doing wrong? Any suggestions? (I like to play crunching metal and some classical from time to time).
Post edited by audiorook on
do you have the gold connector between the two terminals? if not you're either putting power to the tweeters only or the woofers only depending which terminals you connect to.Receiver: Marantz SR6001(for sale)
Fronts: RTi70's black(for sale)
Center: CSi40 black(for sale)
Rears: FXi50 black (sold)
Sub: PSW350 (gone)
TV: Samsung 32" LCD -
Ditto on making sure there's a tight connection. I had the exact same problem when I first hooked up mine (even called polk about it).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
So, your mids and bass are ok ?
There are jumpers which tie the two right channel connectors together, as well as tying the two left channel connectors together at the rear of the speaker cabinet. One set of binding posts is for the woofer, and one set is for the tweeter. If the metal jumper is loose or has shifted out fom underneath the "five way" post, you will lose the tweeter, since your speaker cable is not making connection. Check the jumpers, readjust, ad give them a try. Good luck.[
Thanks for the help. I will check the connections when I get home today. So does it really matter which terminal (top or bottom) I connect my receiver to as long as the connector is in place securely?
On the speaker it doesn't matter as long as the jumpers are in place. Also be sure you didn't cross polarities...
No difference, top or bottom.....let us know how it works out.[
