Sound difference when putting back seat down??
starkiller
have a subaru legacy station wagon and was wondering if there will/would be any sound difference if i kept the back seat down.
thanks!
thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
I would say very little since it is a station wagon:)Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
was just wondering about the boncing of the waves to the hatch and then back. w/o the seat there i didnt know how the waves would respond.Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Here's a noval idea. Try it out instead of asking if it will make a differance to YOUR ears.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
only problem with that is trying to remember what it sounds like with the seat up, then running around, put seat down, and play the tune again and see if you hear a difference
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
sounds a whole lot easier than tuning amps mounted in that area. boy do i wish that was my sound dilema, hmm up, or down. try it a few times. if u have really nice friends u can ask a them 2 close it 4 u. teamwork!Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
a wagon should give u better sound. and it will be best with the seat up.. longest path lenght for the low notes.
place sub in box facing the tailgate. as close to it as acoustically possible. that way, the phase difference between the incident and reflected waves would be the smallest.. hence, less destructive interference.
faced up as far back is prob 2nd best. forward facing against the seat is worst. that's why it would sound better with the seat down. -
explanation... with the sub faced forward into the seat, the sound waves travel from the front of the speaker tru the seat ... and they also travel from the speaker to the back of the car, bounce back and go to the front of the car.
so u get 2 waves.. phase diff.. etc.
if the seat is dropped, then u get more air being pushed from the speaker into the listening area. so this is the reason for better sound with the seat down when the sub is faced into it.
links.. *i searched real hard* .. i read them in the past but nvr bookmarked.
http://www.caraudiobook.com/car_audio_cabin_gain/car_audio_cabin_gain.htm
cant' find the better one :-( -
That's why it's almost always better to face the sub to the rear.
http://www.teamrocs.com/technical/pages/aiming.htm
With the seat down it might be better but it will definitely be different. Are you going to drive around with the seat down all of the time? If not then I would tune with the seat up and turn the sub around to face the rear.HU: 880PRS
Front: SR6500
Amp: Alpine MRV-F545
Sub: SR124-DVC
Amp: Alpine MRD-M1005 -
yeah, am thinking about having the seat down all the time. seems like i am always picking up stuff and never having passengers in the rear.Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Naw, it sounds the same, I have been threatened with divorce over it though..... Oh hold on, I thought you said "putting seat back down". My bad:o
^^ that's the link thats' the link!!!! -
The best way to find out would be to try it. All cars are pretty unique listening environments. No one can really tell you for sure if it's going to sound better either way. Try it out.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
