Raise The Sub?
Demiurge
I live in an upper condo type apartment and while I was at work today I decided to go out in the shop and cut 4 - 1 1\2" X 2 1\2 hollowed square tube to stick under my sub between the sub bottom and the carpet. I thought it would allow for more powerfull bass in the room and lessen the blow on the lady downstairs
I hope I don't sound like I'm off my rocker here, and I haven't set it up like this yet. I'm just wondering if anyone else has done this? Is it a bad thing? Or a good thing? Let me know what you think.
Post edited by Demiurge on
Works well if it is a down firing subwoofer. That is why a down-firing subwoofer is raised off the floor anyways, however I could see the bass volume amazingly......drop if you raise it off the ground. The way the subwoofer sits on the floor, I would think would differ the sound quality. It could possibly be louder, yet boomier. I dont know, try it - don't like it, take it down. However, I do not see any advantages to it.
Calling Doctor S!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!? -
To solve all your problems.......DUDE........YOUR GETTING A DELL!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You're
Let me know what you think.More later,
Tour...
Vox Copuli
And boy did he get a bite, that was entertaining.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
So is anyone else going to comment on the actual question?
I'm still trying to figure out what a 'hollowed rectangular tube' would look like.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Russ, look in the mirror when you take a crap......- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
you mean hollowed metal tube? wood, plastic?? square metal tubing?? I don't follow either,
you have the psw450, so you mean build a platform for it to sut upon, what benny would you get from this unless you had concrete in the form/platform..
Also does the idea i have heard of getting a concrete slab for under the sub really help, or only for a down firing sub.. also the 450 fire forward so again what would lifting it up help any??MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Gold, Gold i tell ya!!!!!!!!! is that like a rounded square??
edit: It's friday and the 13th no less.. wheres all the funny **** forum jokes ??????RussmanMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Heh, Seriously...
It's square so it has 4 sides...you follow?
....ok...
....It's about 1\4 thick on all 4 sides and the middle of it is hollowed. Please don't make me post a picture of it.
I was more looking to see if it would cut down on beating the hell out of the floor and pissing off the neighbor. Not for sound quality purposes. -
It might help cut down a little, depending on how heavy it is, and what it's made of.
The best thing I think of is to isolate the sub from the floor, which can be accomplished by placing it on a heavy peice of slate (from your local garden center).
Cheers,
Russ (aka dickhead)Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
You're
:rolleyes: ....................:rolleyes: DUDE.................*YOU'RE* YOUR GETTING A EFFIN FRIGGIN YOU'RE EFFIN DELL DANGIT! YOUR GETTING ONE!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
"Or you could just take a semi-inflated 12" inner tube and put it under yer sub. Makes my sub more isolated than a russian gulag... Tightens up bass and keeps glasses from falling off my mini bar" -cletusmcgee
Too funny...but I bet it works well.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
