Raise The Sub?
Demiurge
Demiurge Posts: 10,874
I live in an upper condo type apartment and while I was at work today I decided to go out in the shop and cut 4 - 1 1\2" X 2 1\2 hollowed square tube to stick under my sub between the sub bottom and the carpet. I thought it would allow for more powerfull bass in the room and lessen the blow on the lady downstairs :p
I hope I don't sound like I'm off my rocker here, and I haven't set it up like this yet. I'm just wondering if anyone else has done this? Is it a bad thing? Or a good thing? Let me know what you think.
Post edited by Demiurge on
    VR3 Posts: 29,696
    edited June 2003
    Works well if it is a down firing subwoofer. That is why a down-firing subwoofer is raised off the floor anyways, however I could see the bass volume amazingly......drop if you raise it off the ground. The way the subwoofer sits on the floor, I would think would differ the sound quality. It could possibly be louder, yet boomier. I dont know, try it - don't like it, take it down. However, I do not see any advantages to it.
    Calling Doctor S!
  • Demiurge
    edited June 2003
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!?
    VR3 Posts: 29,696
    edited June 2003
    To solve all your problems.......DUDE........YOUR GETTING A DELL!
  • Demiurge
    edited June 2003
    You're
  • Tour2ma
    Tour2ma Posts: 10,177
    edited June 2003
    I think somebody was bored and decided to go fishing... :rolleyes:
    More later,
    Tour...
    Vox Copuli
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2003
    And boy did he get a bite, that was entertaining.
  • Demiurge
    edited June 2003
    So is anyone else going to comment on the actual question?
  • RuSsMaN
    edited June 2003
    I'm still trying to figure out what a 'hollowed rectangular tube' would look like.
    VR3 Posts: 29,696
    edited June 2003
    Russ, look in the mirror when you take a crap......
  • faster100
    faster100 Posts: 6,124
    edited June 2003
    you mean hollowed metal tube? wood, plastic?? square metal tubing?? I don't follow either,
    you have the psw450, so you mean build a platform for it to sut upon, what benny would you get from this unless you had concrete in the form/platform..
    Also does the idea i have heard of getting a concrete slab for under the sub really help, or only for a down firing sub.. also the 450 fire forward so again what would lifting it up help any??
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • faster100
    edited June 2003
    Gold, Gold i tell ya!!!!!!!!! :D:D is that like a rounded square??
    edit: It's friday and the 13th no less.. wheres all the funny **** forum jokes ??????Russman
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Demiurge
    edited June 2003
    Heh, Seriously...
    It's square so it has 4 sides...you follow?
    ....ok...
    ....It's about 1\4 thick on all 4 sides and the middle of it is hollowed. Please don't make me post a picture of it.
    I was more looking to see if it would cut down on beating the hell out of the floor and pissing off the neighbor. Not for sound quality purposes.
  • RuSsMaN
    edited June 2003
    It might help cut down a little, depending on how heavy it is, and what it's made of.
    The best thing I think of is to isolate the sub from the floor, which can be accomplished by placing it on a heavy peice of slate (from your local garden center).
    Cheers,
    Russ (aka dickhead) ;)
    VR3 Posts: 29,696
    edited June 2003
    You're
    :rolleyes: ....................:rolleyes: DUDE.................*YOU'RE* YOUR GETTING A EFFIN FRIGGIN YOU'RE EFFIN DELL DANGIT! YOUR GETTING ONE!
  • LiquidSound
    LiquidSound Posts: 1,261
    edited June 2003
    "Or you could just take a semi-inflated 12" inner tube and put it under yer sub. Makes my sub more isolated than a russian gulag... Tightens up bass and keeps glasses from falling off my mini bar" -cletusmcgee
    Too funny...but I bet it works well.
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
