RTi10 DIY Paint Mod
RedLetterDay
Recently I was bored and decided that I didn't particularly like the silver trim on the front of my RTi speakers along with the black wood frame, so I decided to try and make it the trim black also. I didn't really have too much experience painting but I thought I'd give it a shot and see what happened.
Basically I just removed all of the speakers & cones, cut some cardboard inserts that were the same size to lay over the holes (to prevent any paint from getting inside the actual cabinet), primed the whole thing and then spray painted over it using a flat black enamel. I wasn't able to paint the tweeter because it looked like it was glued/soldered very heavily to the frame and I didn't want to risk breaking it. One of the speakers is still drying but here are some pictures of the one that is finished.
Excuse the color of the screws, I tried using a chemical that was supposed to turn the silver screws to a dark blue color, and it worked -- but shortly afterwards I noticed that they had mostly rusted. Still need to make a trip to the store to pick up some new ones.
Anyways, I'm pretty happy with the result. I definitely like the color better than the silver. There are a couple of areas that maybe should be sanded down and repainted but I was impatient like always and wanted to see how everything looked put together.
Post edited by RedLetterDay on
Those look pretty good front the pictures. And I agree that those silver fronts can be distracting. Good work and welcome.
looks good to me, i like the tube amps better
Looks good, too bad you couldn't dissasmble the tweeter also though.
Nice amp!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I like it. Sexy looking with the black and gray color of the drivers.____________________
Pool: Atrium 60's/45's -
Yeah, the tweeter is incredibly easy to remove from the cabinet though so if I get really annoyed I might try to take it apart some day to paint. I always leave the grilles on though so it really doesn't bother me too much right now.
Thanks regarding the amp(s), hah. -
I really like the look of these. Once the weather clears up a little and I can take them outside, I might try this myself. One thought though...wouldn't painted the tweeter change the sound? I would think that putting paint on it would distort the sound somehow...HT RIG
DISPLAY - Samsung 50A550 Plasma
MAINS - polkaudio RTi10
CENTER - polkaudio CSiA6
REARS - polkaudio M20
SUB - D-Box David 303 (looking into SVS & Velo)
AVR - Yamaha HTR-6190
AMP - Emotiva XPA-3 (:D)
SAT/PVR - Bell HD 6141 1TB HDD
BluRay - 60G PS3
DVD - Pioneer 490-V (1080i upconverting)
POWER - Belkin PF31
REMOTE - Harmony 880
PICTURES HERE
A wise man once said "Friends don't let friends buy Bose" -
Looks great!! Always wondered why POLK didn't make them all black. Even the new RTI A series has the front black (wood) but the trim is silver. Wish I had extra pieces to try it out.
Now try the McIntosh:D -
I always felt the RTis with the silver front looked cheap IMO. These look PHENOMENAL, and truth be told I dig the rusty screws. Only thing out of place is the tweeter.
Same here. Thats why I keep my grills on. -
Do not paint the entire tweeter. If possible, see if you can remove the face plate and leave the diaphragm unpainted."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What about just taping the tweeter? I think that tweeter is glued.
Edit. Just pulled the tweeter out and they use the same black glue as they did on the sda crs crossovers -
Right, it's 2 separate pieces but the problem I had is that the actual tweeter itself has a huge amount of glue or some adhesive holding it attached to the frame. I thought about trying to get it out with a razor blade but didn't really want to risk it. I'll figure something out. :cool: -
The diaphragm may be glued to the faceplate. I wouldn't try to pull the face off unless someone can verify for sure the plate will come off without pulling the diaphragm. I would mask it off, and touch it up with a brush.
Ben -
Not bad at all. I would not paint the actual tweeter either. But the silver around yes. Can't you just curl a piece of paper the size of the dome and carefully paint while holding down the paper over the dome?
The key word here would be carefully...
Nice Job!! They look way better now IMO!!
Welcome to Club Polk also!
Nick -
I was thinking of doing this with piano black high gloss laquer now that you have done it I am more confident I have a really nice airbrush that could do the job.
I thought about doing this as well and I'm too lazy plus I leave the grills on all the time.
