SDA-1C in my living room...
nooshinjohn
i got the sda 1c today and am happy to report all is well
they have never been opened up except for butchered binding posts
already redid them... any andvice or suggestions for enhancing enjoyment of these great speakers?
also are they 4ohm or 8ohm?
thanks
john
thanks
john
Post edited by nooshinjohn on
http://www.polksda.com/sda1creview.shtml
It should be a 4 ohm set. Schematic is in the SDA Sticky at the top of forum.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
New caps and resistors:)
http://www.polkaudio.com/forums/showthread.php?t=55888Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
inspiredsports wrote: »http://www.polksda.com/sda1creview.shtml
You might want to pop the passive radiator to get an eyeball on the crossovers to make sure they match the schematic values if you are going to do the highly recommended crossover upgrade. Some are also upgrading the Interconnect Connection to Cardas and going with custom silver wire based Interconnect Cables with superior resultsVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Congrats!
They are 6ohm. . .
Hi Sal,
Do you have a manual or something other than what I referenced. It's confusing in that it shows nominal 4 ohm, low of 3.9 ohms, but 6 ohms over much of the range.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
The 1C is 6ohms nominal.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
What did the previous owner do to the binding posts?JC approves....he told me so. (F-1 nut)
:)the binding posts were broken off, missing the plastic lock nuts and basically abused. I replaced them with banana plug posts and replaced the original sda terminals with an rca jack. my next step is to replace the top and bottom caps with solid cherry wood caps with a piano gloss finish and recover the grills. as far as the side panels i was thinking about running a strip of cherry from top to bottom about 6 inches wide on the back edge and recovering the remaining side area with grill cloth.
as far as the ohm rating, just so i understand, they are four ohm speakers on mon/wed/fri and 6ohm on tue/thu/sat and sunday should be a day of rest?
thanks for your assistance and support guys:p
johnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
the manual for the 1b shows 5ohm....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »the manual for the 1b shows 5ohm....
1B's and 1C's are not the same. They use different drivers.
Why the concern about what the Ohm rating is?
They are 6 Ohm nominal. They do go lower in the lower frequencies but as the word nominal means................the rating is an average over the entire freq range.
P.s. Did you read the article link in post #2; that will answer your question plus a whole lot more."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
i want to be certain that I am running them properly, as my yamaha reciever is currently set to 8ohm...
.............................................lol i know already.... new amp!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »i want to be certain that I am running them properly, as my yamaha reciever is currently set to 8ohm...
That Yammy won't do them justice. I know it's all you have right now but don't play it too loud and start saving for better amplification. The 1C's will open up and sound 100 times better with quality amplification and a receiver just won;t do them justice.
Enjoy
P.s. You beat me to it. The Yammy will work in the mean time, just don't play it too loud"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Set your Yammi to 4 ohms till you replace it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I just sold my Lsi15 this weekend and was finally brave enough to move my 1C to the living room. My wife didn't freak out but I was very pleased with how they sound. I got 1C months ago and never even attemp to hook them up. Mine are stock but in very good condition. I can't even imainge what they sound like upgraded.Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
I've done tweeter/xo upgrades on two sets of SDA's so far, and the improvement is spectacular.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
I couldn't agree more."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
here are some pictures and information...
near as i can tell they were build in february of 1988 as indicated by the inspection marks on the drivers. the serial # for left is 8331/8271 right...
both cabinet tags state sda1, and no reference made to a,b or c models
the crossovers are quite large and rectangular in shape as shown in the pictures.... ok how the @#!$ do I upload pictures... they are all about 2meg and the system allow 512k. how do i get them into a submittable format?
thanks as always
This will allow you to resize, crop, etc...nooshinjohn wrote: »ok how the @#!$ do I upload pictures... they are all about 2meg and the system allow 512k. how do i get them into a submittable format?
http://www.irfanview.com/"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
thanks for the help in getting the images formatted properly...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I use photobucket to upload my pics. Then I just take and insert the link into the add image button. This works very well.
Ben -
nspindel said these might be sda1b's... any ideas?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
they are 1C's
they are one of the more desirable SDA 1'sPolkFest 2012, who's going>?
nooshinjohn wrote: »nspindel said these might be sda1b's... any ideas?
No, I didn't mean for you to think that you had 1B's. When you described your XO to me, I said that it sounds like my 2B XO.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
sorry... my mis-understandingThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That's a complete different XO than my 1C's.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
perhaps f1-nut or another of our resident gurus has some input?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Wtf, looks like a PB SRS2 crossover."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
It's definitely the same board as my 2B XO, although I see a cap in the C2 position, and resistors in R2 and R3 that aren't present in the 2B's. Here's one of the XO's I pulled from the 2B (before I started taking it apart):
Also looks like there are two extra inductors, one in the location where mine has a ceramic resistor standing up next to C5.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
P/B SRS 2."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
