4 speakers to a 2ch secound zone
ckphoto
I have the Yamaha RX-V663 and would like to run 4-speakers on the second zone, 2 in the living room and 2 on the deck. Can I just hook them all up to the 2 outputs or will this cause problems and are there any other options.
Thanks-
Thanks-
Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One
Post edited by ckphoto on
Do you wish to reuse the front speakers from a Home Theater HT setup for the 2 in the living room? If so you could just add the 2 on the deck to the zone B on the receiver. While the living room is listening in a "Stereo" or 2 channel mode for the living room speaker off the front speaker terminals.
Hope that helps. Or explain your setup a little better for us old guys.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I would use a simple speaker selector box between the zone 2 outputs and the 2 pair of speakers. These boxes have impedance protection so that you don't overdrive your receiver, and also have the benefit of allowing you to switch each pair on or off independently.
Something like this would be sufficient. Niles and Adcom make more upscale versions.
http://www.htd.com/speaker-cables-accessories/Speaker-Selectors/SS41-Speaker-Selector5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
My receiver which is located in my downstairs den has a zone 2 that can play from a separate source. I would like to have speakers in my up stairs living room and on my deck running of the 2 channel zone 2 for music when entertaining.Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One -
If both sets of speakers are 8 ohms, you should be able to do that without issues.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Thanks Adam exactly what I need.Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One -
But if 8 ohms running them together off the "Zone B" output is a 4 ohm load... Maybe not a good thing to do. If that the case I like Adams idea of speaker switch box as these would add some resistance to help the receiver "See" a 8 ohm load at all times.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
4 ohms shouldn't be an issue on most any modern amp. Increasing the resistance will just reduce his amp power.TNRabbit
Sunfire TG-IV
You're welcome.
Also, if you haven't bought speaker wire yet, HTD has good quality in-wall speaker wire for a good price. I've used both the 2 and 4 conductor 14 awg at a friend's house.
Another tip - you could run 4 conductor wire from the receiver to a convenient spot upstairs and locate the speaker selector there. Then, run wire for each pair from there. This would allow you to select the living room and deck speakers without going downstairs.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Being able to switch the living room and deck speakers on or off independently is reason enough to use a selector box. For example, you would not want your deck speakers on if you're not outside.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
