4 speakers to a 2ch secound zone
ckphoto
ckphoto Posts: 121
edited January 2009 in Electronics
I have the Yamaha RX-V663 and would like to run 4-speakers on the second zone, 2 in the living room and 2 on the deck. Can I just hook them all up to the 2 outputs or will this cause problems and are there any other options.
Thanks-
Mitsubishi WD-73736
Pioneer Elite SC-05 :D
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One
Post edited by ckphoto on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2009
    Do you wish to reuse the front speakers from a Home Theater HT setup for the 2 in the living room? If so you could just add the 2 on the deck to the zone B on the receiver. While the living room is listening in a "Stereo" or 2 channel mode for the living room speaker off the front speaker terminals.
    Hope that helps. Or explain your setup a little better for us old guys. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • adam2434
    adam2434 Posts: 995
    edited January 2009
    I would use a simple speaker selector box between the zone 2 outputs and the 2 pair of speakers. These boxes have impedance protection so that you don't overdrive your receiver, and also have the benefit of allowing you to switch each pair on or off independently.
    Something like this would be sufficient. Niles and Adcom make more upscale versions.
    http://www.htd.com/speaker-cables-accessories/Speaker-Selectors/SS41-Speaker-Selector
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • ckphoto
    ckphoto Posts: 121
    edited January 2009
    My receiver which is located in my downstairs den has a zone 2 that can play from a separate source. I would like to have speakers in my up stairs living room and on my deck running of the 2 channel zone 2 for music when entertaining.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
  • TNRabbit
    TNRabbit Posts: 2,168
    edited January 2009
    If both sets of speakers are 8 ohms, you should be able to do that without issues.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • ckphoto
    ckphoto Posts: 121
    edited January 2009
    adam2434 wrote: »
    Thanks Adam exactly what I need.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
  • disneyjoe7
    edited January 2009
    But if 8 ohms running them together off the "Zone B" output is a 4 ohm load... Maybe not a good thing to do. If that the case I like Adams idea of speaker switch box as these would add some resistance to help the receiver "See" a 8 ohm load at all times.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • TNRabbit
    edited January 2009
    4 ohms shouldn't be an issue on most any modern amp. Increasing the resistance will just reduce his amp power.
    TNRabbit
    Sunfire TG-IV
  • adam2434
    adam2434 Posts: 995
    edited January 2009
    You're welcome.
    Also, if you haven't bought speaker wire yet, HTD has good quality in-wall speaker wire for a good price. I've used both the 2 and 4 conductor 14 awg at a friend's house.
    Another tip - you could run 4 conductor wire from the receiver to a convenient spot upstairs and locate the speaker selector there. Then, run wire for each pair from there. This would allow you to select the living room and deck speakers without going downstairs.
  • adam2434
    adam2434 Posts: 995
    edited January 2009
    Being able to switch the living room and deck speakers on or off independently is reason enough to use a selector box. For example, you would not want your deck speakers on if you're not outside.
