Entry level Velo experiment
Lowell_M
I had my ADCOM GFA-555 disconnected from my 2-channel to demo a Marsh A200s (thanks dkg999) and thought I'd mess around with the ADCOM in my HT a little.
I've wondered for some time, but been to lazy, how the addition of a quality amplifier to my Velodyne CHT-12 sub instead of using the velo's internal amp might effect the subs performance. So, I connected the ADCOM in all of its gargantuan bridged glory. (hell, the ADCOM is half the size of the entire sub) I know that others have used the GFA-555's with some of the unpowered SVS tubes and have been very happy, but this test is different. Can an entry level sub sound good or even great with amplification better than the cheesy little plate amp that it came with?
The short answer is, "WOW YES!"
The longer answer is... The dynamics and overall output of the sub increase dramatically. I used the Transformers movie as my reference and was feeling things I didn't even hear before. And it wasn't just a gain issue. I had it somewhat calibrated so that output would be where it should, but the sub was able to keep up with some of the dynamic peaks that it couldn't before.
The driver never sounded like it was being strained. In fact, I turned the gain up a bit to see what happened and response was huge without any bottoming out. (I didn't want to go too far of course though)
The bad news... You are still working with an entry level driver in an entry level box. Port noise was an even bigger issue than before because there was more air moving. Response tightened up but still not near what I have heard in some of the SVS's and other higher end subs.
So, if you have a spare ADCOM GFA_555 sitting around and a low end Velodyne, by all means, use it as your sub amp. Is buying an amp like the GFA-555 a good upgrade solution for your entry level amp? Nope. Your money would be better spent on a sub designed to perform better.
Sure was a fine experiment though. My basement has never experienced such pressurization.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
I used my 555 to power my Titanic MKIII 15" Sono, and loved it. I broke the cone loose from the driver in chapter 13 of WOW. It kinda snuck up on me:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
How exactly did you connect 555 to the driver?
Wouldn't you need at least a cross-over in-between, since the amplifier amplifies the entire frequency range?Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I disconnected the IC from the LFE input on the sub and connected it to the mono input on the ADCOM. Then ran speaker wire from the ADCOM to the speaker level inputs on the Velodyne. The signal is already crossed over from my AVR, but there is also a crossover on the Velodyne.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
Is that one of the kit subs from Parts Express? How do you like that? I've been looking at them, and they look pretty nice. I was considering maybe checking one of those out instead of the SVS PB10 I've been looking at. It'd cost roughly the same, and looks like it might pack a lot more punch. The cone breaking loose isn't really a good sign though.
Sounds like a fun little experiment. Maybe I should get an Adcom 555 to power my **** little Pioneer 8" sub...lol...it'd pack a bit more punch than the 50 watt onboard amp I'm sure...probably also blow the woofer in the process though...The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
heh heh... I guess my Velo isn't as entry level as I make it sound, but it's nothing compared to the SVS's out there. It's got a 12" driver and ... i think something like a 150watt amp. I used to think it kicked ****, but after hearing the MicroPro 2000 and some SVS's .... I realize its just ok. Much better than your average HTIB.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
R u home? We gotta get going!!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
comfortablycurt wrote: »Is that one of the kit subs from Parts Express? How do you like that? I've been looking at them, and they look pretty nice. I was considering maybe checking one of those out instead of the SVS PB10 I've been looking at. It'd cost roughly the same, and looks like it might pack a lot more punch. The cone breaking loose isn't really a good sign though.
http://www.polkaudio.com/forums/showthread.php?t=51533
When it broke I had the tube volume at 9' cubed. This brought the power handling down to 500 or so watts. I shrank the enclosure to about 5' cubed, for better power handling, but it was better to feed it less watts in a bigger tube. As for the woofer breaking I think it was an isolated incident. Sub bass with a little too much power.
Ben -
But then wouldn't the output of the Adcom just be driving the Velo's internal amp ,albeit through dropping resistors to bring it down to a useable level?a_mattison wrote: »Then ran speaker wire from the ADCOM to the speaker level inputs on the Velodyne.Testing
Testing
Testing -
I am hoping he meant he hooked the amp up directly to the driver
Ben -
That would be the way to do it,but his actual wording is "speaker level inputs".I am hoping he meant he hooked the amp up directly to the driver
Testing
Testing
Testing -
I am such a jack ****. I thought the speaker level inputs were passive right to the driver. So, now I'm not sure what the hell I accomplished with this little experiment.
My audiophile membership card should be revoked. At least my amp has 200 wpc even if I can't use it right.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
I guess if you didn't recalibrate the subs level when you hooked up the Adcom,the actual levels may having been somewhat higher thus giving the impression of greater output and dynamics etc.a_mattison wrote: »So, now I'm not sure what the hell I accomplished with this little experiment.Testing
Testing
Testing -
a_mattison wrote: »I made it there didn't I?!
Yep, too bad you lost your membership card. Had I known..................I would have ripped it up in front of you!!!!
Sorry the band wasn't playing tonight."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Band? What band?;)
Ben
Wow...I think I might want to try building one of these. Sounds like a badass sub. You may be getting some messages from me looking for help on this in the future.
