Custom A1 IC for SDA's
ben62670
ben62670 Posts: 15,969
edited January 2009 in Vintage Speakers
Well I built one of these for a friend. The case is cast. The cables are Silver Plated with a small adapter so you can Bypass the A1(I call it the Silver Bullet) and still use the A1 IC wires.
Yes my camera sucks. It doesn't have all those white spots;)
Ben
Ben
Post edited by ben62670 on
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    nice work,, care to disclose whats hiding in the larger case:)
  • ben62670
    edited January 2009
    It's an Avel toroidal Y23 transformer:)
    Ben
  • bsoko2
    bsoko2 Posts: 1,449
    edited January 2009
    Thanks Ben, the unit is has exceded my expectations. Listening to music in Stereo and watching BluRay has become a new experience of enjoyment. I have had several friends over to hear my system and they have been amazed by the difference from before to now.
    Bill
  • ben62670
    edited January 2009
    Very cool:) I have heard that from others. The sad thing is now I want one! I do like how the single connector worked out, and the cast case:) I think I need to clean my camera lens:(
    Thanks Bill.
    Ben
    Ben
    heiney9 Posts: 25,522
    edited January 2009
    How much to build one for me?
  • ben62670
    edited January 2009
    As always. Parts plus a little. Actually there are a few options to go over.
    PM sent.
    Ben
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Would y'all think I was a total idiot if I asked what it was and what it did?
  • Systems
    Systems Posts: 14,872
    edited January 2009
    Nice work,good choice using the Speakon connectors but whats with the rusty screws?
    Testing
    Testing
    Testing
  • Systems
    edited January 2009
    Bigerik wrote: »
    Me thinks it allows non common ground amps to be used with SDA's.
    Testing
    Testing
    Testing
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    GV#27 wrote: »
    Well, in that case, it is very cool!
    Nice work.
    edited January 2009
    ben62670 wrote: »
    PM sent.
    Got your PM, I'll be in touch soon.:)
  • ben62670
    edited January 2009
    GV#27 wrote: »
    It's my crappy camera. There are no white spots either:(
    Speakon connectors are a fool proof way to easy way to disconnect the cable. You can do it in the dark and never get the polarity wrong:)
    Ben
  • george daniel
    edited January 2009
    GV#27 wrote: »
    Georgia humidity;) I have actually seen this one,, or one that Ben made,and the build quality is very,very good.Although he won't admit it,, I suspect that they tried it out on my SDA's before I picked them up.;):)
  • ben62670
    edited January 2009
    Edit:
    I sent him an email. That top screw on the right has a spot on the outside:( Next one I am using Nickel or stainless.
    Ben
  • Systems
    edited January 2009
    ben62670 wrote: »
    I know what you mean,I ve taken pics with my cheap Kodak with similar results ,things that you don't really see with the eye show up in the pics.:confused:I was just fun'in ya it wasn't meant as criticism.The cable dressing and connectors all look top notch.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    Thanks GV. My old Nikon took excellent pics. It died. I bought a newer better model, but any closeup shoot and it really kills the pics. I wish I could afford another camera. I need to take some cable pics. The cables look much better in person than the pics do too:(
    Well I contacted him, and
    Didn't notice any rust. The unit is on a lower shelf in the rack so I won't
    be going down on my hands and knees to see.
    Bill
    BTW the screws are black oxide. I want to keep them black, but if they are prone to discolor, or rust I may make a change.
    Ben
    treitz3 Posts: 20,131
    edited January 2009
    You definitely do NOT want to drop this on your feet! You'd be walkin' funny for some time. Excellent build quality to boot. I checked this bad boy out while down at Ben's. Knowing me, I'll be getting one eventually for my 1C's.
  • bsoko2
    bsoko2 Posts: 1,449
    edited January 2009
    I got a hernia lifting it to the lower shelf on the media center!
    Bill
  • ben62670
    edited January 2009
    They certainly are heavy. I chose the cast case for it's strength in case of an accidental drop, and for even more RF rejection.
    Ben
  • Aldous_Huxley
    Aldous_Huxley Posts: 76
    edited January 2009
    Bigerik wrote: »
    Same here, i have no idea what that thing does.
  • george daniel
    edited January 2009
    it allows one to either use it as the normal interconnect (between the speaks) and/or allows you to use non common ground amplification by a simple switch of the "black box),, such as monobloc's. DK has a thread also,, use the search function,, AI-1 or dreadnought.
  • Face
    Face Posts: 14,340
    edited January 2009
    No nudes? You tease!
  • ben62670
    edited January 2009
    Yes Master:D
    I terminated the wires with fast ons. Then I soldered the fastons to the Speakon connector:) Nothing is coming loose in there:)
    DSCN1338.jpg?t=1232382954
    I'll take better pics next time.
    Ben
    Ben
