How much difference in quality btwn HD and Bluray?
starkiller
starkiller Posts: 2,723
edited January 2009 in Electronics
was wondering how much differnce there is quality wise btwn hd and bluray. with hd discs on clearance everywhere and the availability of used hd players i can be spending a heck of a lot less then a bluray player that will work with my outlaw 950.
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • danger boy
    danger boy Posts: 15,722
    edited January 2009
    there is not much difference between the two. but HD DVD's are no longer being produced... so finding movies to watch once you've purchased or watched all of them is going to suck.
    you'd be safer going with Blu Ray.. it's going to be around for a long time.
    PolkFest 2012, who's going>?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    I'd go with a Blu-ray myself. Like Danger Boy said...HD DVD's aren't being produced anymore...so once you're done snagging up all the deals that are out there...that'll be it. They won't be making any more of them.
    What you could do is get a player that will play both Blu-ray and HD DVD, and you'd still be able to snag up some of those deals on HD discs. I know LG makes a player that will play both...and I wanna say Pioneer does too...I'm not positive though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • manman
    manman Posts: 256
    edited January 2009
    yeah, as said before, quality is nearly the same, and no new HD-DVD's are being produced. But if you're on a budget and don't already have an upscaling dvd player, some of those old hd-dvd players are great for that purpose, plus you get to play cheap hd-dvd's all for a pretty good price.
    you can also check out some sites like highdefdigest.com to find a list of movies on both formats and see if the existing collection of hd-dvd's would be worth it to you.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • mantis
    mantis Posts: 17,476
    edited January 2009
    I was able to do a shoot out between with Superman Returns as it was released on both formats side by side. I had 2 Pioneer Elite 50 inch, 1 Elite Blu and Toshiba HD players and the Blu ray looked like a cleaner transfer. Not by much, it was not night and day. The sound seemed almost the same as well. Without having one or the other there, you would have been happy either way.
    The problem now is HD is not made anymore so even if it was better( I only judged it with one disc) it doesn't matter now.
    Dan
    Dan
  • Hamsterman
    Hamsterman Posts: 13
    edited January 2009
    Thanks for the info!
