B1 Buffer Preamp
zingo
zingo Posts: 11,258
edited March 2013 in DIY, Mods & Tweaks
I am going to start point-to-pointing the Pass Labs B1 Buffer Preamp in a week or two when I get some time. I have attached the schematics with transposed part specs for anyone else who wants the information.
Post edited by zingo on
«1345
  • zingo
    zingo Posts: 11,258
    edited January 2009
  • strider
    strider Posts: 2,568
    edited January 2009
    Did you give up on waiting on the PCB? I've been checking the site every once in a while and haven't seen them become available again.
    I'll look forward to your updates.
    Wristwatch--->Crisco
  • zingo
    zingo Posts: 11,258
    edited January 2009
    I did get tired of waiting for the board... And since it has so few parts anyway, I'll just get a breadboard and do it myself.
  • strider
    edited January 2009
    I ended up buying one from Tim Rawson instead of trying to build one without the board. Even though there's a low parts count and it seemed pretty straight forward, I got intimidated/confused reading the threads on diyaudio.com.
  • zingo
    zingo Posts: 11,258
    edited January 2009
    Ya, those threads were a little intimidating, but I figure that's the best way to learn. :D
  • Face
    Face Posts: 14,340
    edited January 2009
  • Systems
    Systems Posts: 14,872
    edited January 2009
    I posted the B1 schem awhile back.http://www.polkaudio.com/forums/showthread.php?t=69722&highlight=PASS+PREAMP.Looks like a great little pre,if I didn't already have a Pass Jfet clone then I would probably build one of these or the B3.If I where to build it I think I would use the bipolar 9 volt power supply so as to eliminate the need for costly output caps.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited January 2009
    Btw, I would avoid using Jantzens that are in the picture above.
  • zingo
    zingo Posts: 11,258
    edited January 2009
    What was wrong with the Jantzen caps? I used them in my Monitor 5Jrs with good success.
  • zingo
    zingo Posts: 11,258
    edited January 2009
    GV#27 wrote: »
    I was looking at running it off a pair of 9v batteries to totally avoid A/C. Am I missing something with the bipolar power supply? The specs sheet says it required between 18-24v.
  • Face
    Face Posts: 14,340
    edited January 2009
    zingo wrote: »
    IMO, I thought they sounded terrible in the B1. I replaced them with Sonic Caps and there was a large improvement. They may not be as bad in a speaker crossover.
  • Systems
    edited January 2009
    zingo wrote: »
    You can use a single 18 volt supply or a +-9 volt.I haven't checked the thread at DiyAudio in awhile but I think some builders intended to use batteries.
    Testing
    Testing
    Testing
  • zingo
    zingo Posts: 11,258
    edited January 2009
    Where did you get the chassis Face? Your completed product looks fantastic!
  • Systems
    edited January 2009
    zingo wrote: »
    If you are looking for a nice chassis for your B1 one of these Hammonds would do nicely.http://www.hammondmfg.com/1455ptbla.htm
    They come in several sizes and with either plastic or metal fronts. I have used them for several projects.I used a small one for this passive pre.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited January 2009
    I bought mine used and I believe the case is unavailable.
  • Systems
    edited January 2009
    Face wrote: »
    Too bad because they look great.
    What didn't you like about the Z caps?
    Testing
    Testing
    Testing
  • Systems
    edited January 2009
    GV#27 wrote: »
    Oooops,make that Jantzen caps.
    Testing
    Testing
    Testing
  • Gaara
    Gaara Posts: 2,415
    edited January 2009
    zingo wrote: »
    For my last couple projects Tim went with Diyenclosure. Not sure if it is the same company but it looks similar to my BPA200 and 200asc, just smaller.
  • Face
    Face Posts: 14,340
    edited January 2009
    GV#27 wrote: »
    I found them rolled off up top and not very coherent.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Face wrote: »
    Thats what I got doing my cap shoot out on speakers. Solen's were too hot brittle, Jantzen's were better, but kinda lifeless, and Dayton's came out on top.
    Ben
  • zingo
    zingo Posts: 11,258
    edited January 2009
    I'm kind of surprised that I liked them then in my 5Jrs, because I really like the Sonicaps in my 4.1TLs. Or maybe they just work well with those speakers. I will be building this with Daytons however since I have had good results with them in electronics before.
  • strider
    edited January 2009
    Are the Jfet's hard to source for this thing, or am I remembering incorrectly?
  • zingo
    zingo Posts: 11,258
    edited January 2009
    I believe that the 2SK370 can be hard to find, but here is a link to the also approved LSK170:
    http://www.ka-electronics.com/FETS/FET.htm
    FYI: The 2SK170 is also approved to be used
  • zingo
    zingo Posts: 11,258
    edited January 2009
    Parts List:
    2SK370 Transistor 4x
    1N914 Diode
    Generic LED
    15000 uF 2x
    10 uF 2x
    1 uF 3x
    1 ohm
    1k ohm 4x
    10k ohm 2x
    15k ohm
    25k ohm 2x
    221k ohm 2x
    1M ohm 6x
    2 way switch
    RCA jack 6x
  • Face
    Face Posts: 14,340
    edited January 2009
    I remember reading that if you contact Pass Labs, they may be able to sell you a board. They're leaving the "out of stock" message up on their page due to them not being able to meet demand.
    I may actually grab a second one.
  • zingo
    zingo Posts: 11,258
    edited January 2009
    Updated Parts List:
    2SK370 N channel JFET Transistor 4x (GR or BL grades)
    1N914 Diode
    Generic LED
    15000 uF 2x Electrolytic 25v
    10 uF 2x Film
    1 uF 3x Film
    1 ohm 3w
    1k ohm 4x .25w
    10k ohm 2x .25w
    15k ohm .25w
    25k ohm 2x .25w
    221k ohm 2x .25w
    1M ohm 6x .25w
    2 way switch
    RCA jack 6x
    Linear Taper Pots 25k 2x
  • zingo
    zingo Posts: 11,258
    edited January 2009
    Face wrote: »
    The first time I contacted them, they said they were out. I contact them back a month later a few times but haven't received any updated responses. I figured since there were so few parts and it's not high voltage, point-to-point would be a good route.
  • Face
    Face Posts: 14,340
    edited February 2009
    Face wrote: »
  • strider
    New wiring, Mike?
    Daytons in mine. Finally checked tonight.
  • Face
    Face Posts: 14,340
    strider wrote: »
    New wiring, Mike?
    Kinda. ;)
    Good! Be glad.
