B1 Buffer Preamp
zingo
I am going to start point-to-pointing the Pass Labs B1 Buffer Preamp in a week or two when I get some time. I have attached the schematics with transposed part specs for anyone else who wants the information.
Post edited by zingo on
Did you give up on waiting on the PCB? I've been checking the site every once in a while and haven't seen them become available again.
I'll look forward to your updates.Wristwatch--->Crisco -
I did get tired of waiting for the board... And since it has so few parts anyway, I'll just get a breadboard and do it myself.
I ended up buying one from Tim Rawson instead of trying to build one without the board. Even though there's a low parts count and it seemed pretty straight forward, I got intimidated/confused reading the threads on diyaudio.com.Wristwatch--->Crisco
Ya, those threads were a little intimidating, but I figure that's the best way to learn.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I posted the B1 schem awhile back.http://www.polkaudio.com/forums/showthread.php?t=69722&highlight=PASS+PREAMP.Looks like a great little pre,if I didn't already have a Pass Jfet clone then I would probably build one of these or the B3.If I where to build it I think I would use the bipolar 9 volt power supply so as to eliminate the need for costly output caps.Testing
Testing
Testing -
Btw, I would avoid using Jantzens that are in the picture above."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What was wrong with the Jantzen caps? I used them in my Monitor 5Jrs with good success.
I was looking at running it off a pair of 9v batteries to totally avoid A/C. Am I missing something with the bipolar power supply? The specs sheet says it required between 18-24v. -
IMO, I thought they sounded terrible in the B1. I replaced them with Sonic Caps and there was a large improvement. They may not be as bad in a speaker crossover.What was wrong with the Jantzen caps? I used them in my Monitor 5Jrs with good success."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
You can use a single 18 volt supply or a +-9 volt.I haven't checked the thread at DiyAudio in awhile but I think some builders intended to use batteries.I was looking at running it off a pair of 9v batteries to totally avoid A/C. Am I missing something with the bipolar power supply? The specs sheet says it required between 18-24v.Testing
Testing
Testing -
Where did you get the chassis Face? Your completed product looks fantastic!
If you are looking for a nice chassis for your B1 one of these Hammonds would do nicely.http://www.hammondmfg.com/1455ptbla.htmWhere did you get the chassis Face? Your completed product looks fantastic!
They come in several sizes and with either plastic or metal fronts. I have used them for several projects.I used a small one for this passive pre.Testing
Testing
Testing -
I bought mine used and I believe the case is unavailable."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Too bad because they look great.I bought mine used and I believe the case is unavailable.
What didn't you like about the Z caps?Testing
Testing
Testing -
Testing
Testing
Testing -
For my last couple projects Tim went with Diyenclosure. Not sure if it is the same company but it looks similar to my BPA200 and 200asc, just smaller. -
I found them rolled off up top and not very coherent.
Thats what I got doing my cap shoot out on speakers. Solen's were too hot brittle, Jantzen's were better, but kinda lifeless, and Dayton's came out on top.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I'm kind of surprised that I liked them then in my 5Jrs, because I really like the Sonicaps in my 4.1TLs. Or maybe they just work well with those speakers. I will be building this with Daytons however since I have had good results with them in electronics before.
Are the Jfet's hard to source for this thing, or am I remembering incorrectly?Wristwatch--->Crisco
I believe that the 2SK370 can be hard to find, but here is a link to the also approved LSK170:
http://www.ka-electronics.com/FETS/FET.htm
FYI: The 2SK170 is also approved to be used -
Parts List:
2SK370 Transistor 4x
1N914 Diode
Generic LED
15000 uF 2x
10 uF 2x
1 uF 3x
1 ohm
1k ohm 4x
10k ohm 2x
15k ohm
25k ohm 2x
221k ohm 2x
1M ohm 6x
2 way switch
RCA jack 6x -
I remember reading that if you contact Pass Labs, they may be able to sell you a board. They're leaving the "out of stock" message up on their page due to them not being able to meet demand.
I may actually grab a second one."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Updated Parts List:
2SK370 N channel JFET Transistor 4x (GR or BL grades)
1N914 Diode
Generic LED
15000 uF 2x Electrolytic 25v
10 uF 2x Film
1 uF 3x Film
1 ohm 3w
1k ohm 4x .25w
10k ohm 2x .25w
15k ohm .25w
25k ohm 2x .25w
221k ohm 2x .25w
1M ohm 6x .25w
2 way switch
RCA jack 6x
Linear Taper Pots 25k 2x -
The first time I contacted them, they said they were out. I contact them back a month later a few times but haven't received any updated responses. I figured since there were so few parts and it's not high voltage, point-to-point would be a good route. -
New wiring, Mike?
Daytons in mine. Finally checked tonight.Wristwatch--->Crisco -
