Monster Cable Jargon Hooplah
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    I heard he doesn't wear underwear:eek: and those chaps:)
    Ben
  • ben62670
    edited January 2009
    I eat boogers for breakfast:mad:
    Ben
  • wald0
    wald0 Posts: 62
    edited January 2009
    Also, that Monster connector/adaptor thing isn't even really that great by concept. Just by using a connector you're creating a gap in the signal flow. With these connectors there are two gaps in the signal flow now.
    Not quoting you as right or wrong, but now you've got me thinking. From a kind of scientific point of view, that would be true, because the threads are round and not every part of even the outside threads could be technically touching the connector (if you were to zoom in really close). Now the only question is whether or not the current/signal could jump across the [tiny] gap to the connector just as easily as it could go through the wire. If not, then yes there would be a gap in the flow. Now a matter of judgement can be applied as to how big of a deal that is. But I have heard some people say that using a connector is only gives one more place where connection can fail. :/
    But then you could say that using a connector has a better shape for touching the wire threads than certain direct connect options.
    WARNING: ^ ^ ^ Unnecessarily articulate observations ^ ^ ^
    In my opinion, even though I do get caught up in these incredible debates with myself about the finite characteristics of wires, I think the if you have a balanced set of RCAs, and some oxygen-free, twisted speaker cable in the right gauge, you are good to go.
    -wald0
    Edit: wow I didn't read all the way down, and I didn't realize this thread went to goofing off, must be a tired idea of a topic. :P
  • gdb
    gdb Posts: 6,012
    edited January 2009
    ben62670 wrote: »
    What their speaker wire that turns green with age? Crap RCA's? If you want to go real cheap with speaker wire WalMart has decent 14ga wire in the Automotive department. Not the stuff in electronics.
    I think he was talking about HD's 12ga outdoor lighting cable, it's got a tough black insulation,zip cord config. & rated for direct burial too. Not sure though!:)
  • Face
    Face Posts: 14,340
    edited January 2009
    I had Monster Cable that turned green.
  • Face
    Face Posts: 14,340
    edited January 2009
    asd1234 wrote: »
    Just go to Home Dept. and get some cables there. It will save you $ and get better quality.
    Yes, it goes great with curbside and dumpster diving finds.
    F1nut Posts: 51,920
    edited January 2009
    Face wrote: »
    Sig material there!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    wald0 wrote: »
    -wald0
    I'm sure the difference in SQ that would result from using a two part connector like that is minimal...and most people probably wouldn't even notice it. In theory though...like you said, it's just one more possible spot for the connection to fail.
    Like I said before...unless you have to change connector styles a lot, there's not really much of a point, and you'd be better off just going with a solid connector. It's great if you do have to change connectors a lot though, which I'm sure some people do.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ben62670
    edited January 2009
    Face wrote: »
    I think I peed my pants:D LOL
    Ben
  • Mike Kozak
    Mike Kozak Posts: 931
    edited January 2009
    I bought 50 feet of 14awg wire at Home depot this past weekend. Will hook up my Monitor 10s with it. 21.00
  • SEH
    SEH Posts: 91
    edited January 2009
    wald0 wrote: »
    Um, no, from a scientific point of view it's completely bogus. This is easily verified with a meter.
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    Face wrote: »
    Gold Jerry,Gold
  • SEH
    SEH Posts: 91
    edited January 2009
    There's no difference in sound quality. None. It's too silly to even debate.
    And there's zero chance of that connection failing. The wire connection to the banana (or base in this case) is what has an actual chance of failing, so if you're that worried you must use unterminated wire.
  • comfortablycurt
    edited January 2009
    SEH wrote: »
    Well then you can go ahead and use them if you want. It seems like a bad concept to me, and I think I'm going to continue thinking that.
    A solid piece of metal is a better conductor than two pieces of metal that are touching each other. The same reason you wouldn't want to connect two lengths of speaker wire together. To debate that fact would be silly.
    Like I said...the difference in SQ is probably minimal at most...more likely nonexistant. How many things are there in the audiophile world that make no difference on paper, or through test equipment, but make a difference in your ears? Certain things can't be proven through scientific methods.
    So like I said...if you want to spend twice the money to have a two piece connector, you're more than welcome to. I think I'll stick with one piece connectors, because it makes more sense to me.:D
    Curt
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited January 2009
    Mike Kozak wrote: »
    You spent more than needed on a product that will turn green over time....
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
    better wire better price no green.:cool:
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • SEH
    SEH Posts: 91
    edited January 2009
    In this case, it's not. They are the same as one for conductivity, and in fact more capable than the wire itself.
    Indeed.
    You know what makes it even more silly? It's not like regular banana connectors are carved from a single chunk of billet. Most of them are multiple pieces, with the tip being a different piece from the body, and then the springs being more separate pieces. That's a lot of non-solid metal to go through. And that's before we consider the plating. I guess you get your connectors unplated though, right, to avoid the extra "gap" in electron flow?
    Have you even checked these with your ears? Or are you just speculating? There are a ton of people here using modular connectors, and you would be the first to ever bring up a SQ issue (I searched to be sure). I've heard iconns with just the pin, or with bananas or spades attached. I can hear no difference. Would MIT routinely terminate their wires with something that effs up the sound? Seems unlikely, but maybe they need you and your ears to set them straight.
  • agfrost
    agfrost Posts: 2,473
    edited January 2009
    Nothing like a speaker wire or M* cable thread to bring out the warm and fuzzy in all of us. ;)
    Jay
    Jay
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2009
    suprafantx wrote: »
    Should I buy Monster cables if I can get them with 75% discount?
    That might make sense, but may prove the point. Is that directly from Monster for "firsts" (no cosmetic problems, no returns, etc.)? If they are firsts from Monster at 75% off. They probably still made a decent profit because of their high marketing created margins.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Mike Kozak
    edited January 2009
    So I did, lesson learned
  • ben62670
    edited January 2009
    OK confession time. I own a monster cable:o I was getting some electronic parts at rat shack and there was some ~m~ digital cables on sale $5 marked down from $70. They were selling a cable that "costs" $70 for $5. Kinda says a little about the wire itself. Fancy jacket and heavy marketing. Add to the fact that they sue everyone who uses the word monster in business whether cable related or not. I won't give them any of my money. I went though a short monster phase. Their cheaper wire is crap like the "time corrected" XP stuff with some sort of tube in it. After you strip all the plastic out of it it is like 18ga wire. I'll pass. All that ~m~ cable I used is in the trash(whole surround sound system). I would not even give it away. It belongs in the dumpster where I sent it. As for the "expensive" cheap digital cable it is being used on my cheap DVD changer for kids movies 2 channel style;)
    Ben
    Ben
  • inspiredsports
    edited January 2009
    check it out! :eek:
    Peed my pants when I read it !!! My wife has had to do 3 loads of laundry since I started reading this thread.
    Is it from the Onion? I think the price should have been 15.8 dollars.
    NAD SS rigs w/mods
    GIK panels
  • ben62670
    edited January 2009
    Someone is going to get sued...
    Ben
  • davidk0512
    davidk0512 Posts: 157
    edited January 2009
    ben62670 wrote: »
    Ben
    I just removed some of the XP stuff a couple of weeks ago and replaced with Belden 12 from Bluejeans. I don't remember how long I've had it, but it turned greasy and green from end to end on 10 foot runs. I've saved it in my garage to use as an example of what not to use. I always wondered what that string of plastic core tubing was for, maybe it's like the fillers in low quality dog food - no nutritional value, but a lot more **** produced.
    David
  • ben62670
    edited January 2009
    It makes it look like there is some copper in there, and another revolutionary design by ~m~:rolleyes:
    Ben
  • comfortablycurt
    edited January 2009
    SEH wrote: »
    Indeed.
    Get your panties out of that bunch they're in buddy. ;) That's just the way I see it. As I said...you are more than welcome to use your two piece connectors if you want. I myself...will use a one piece connector.
    I don't care if it's just the same on paper or whatever...it SEEMS like a bad idea IN MY OPINION. Nothing you can say is ever going to change that opinion either.
    Go ahead and use those connectors if you so wish...as I've said a few times now...I see no purpose for it whatsoever for my personal needs. If it would be useful for you...great...go for it. I don't want them.
    You need not continue trying to sway my opinion...because it's already made up.
  • joev11
    joev11 Posts: 22
    edited January 2009
    wald0 wrote: »
    I think it is for people for whom money is no object. I'm sure they are the best granted cost isn't a factor?
    Monster cables are designed for people who like to "watch" the music as well as listen to it. These are the same people who bought a foreign car back in the 1980's and paid over sticker price for it, then actually bragged about it to their friends.
  • joev11
    joev11 Posts: 22
    edited January 2009
    FInut, I heartily agree with and applaud your tag line. Would that more would see and understand the truth.****************************************************************
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a **** by the clean end."
