Monster Cable Jargon Hooplah
wald0
wald0 Posts: 62
I'm waiting for my Monitor 10's to come but I need to order some decent cable for them. I think you have to work in a stereo store to understand the ideology of Monster cables. Yes they are great, but what is the difference between the Monster Lock Master Pin connectors and the Bananas, and which will I want for my Monitor 10's? The pictures for both are the same. Monster says they only sell them here:
http://www.shopallmonster.com/nav/monster/productdetails.aspx?pin=37&pid=21895
This site says I need "Monster Lock Tips" for the "Monster Lock Master Pins" (phew) I would assume that the Master tips would be ready to plug in if they come as a pre-made 10 footer? That's not what it seems like though. Do I have to buy a tip adapter by default just to use a $74 pair of connectors? That would be some **** if you ask me.
Sorry about all the rambling but I barely understand this stuff, never looked at a MOnster Cable that close. But they sure sound sweet.
Post edited by wald0 on
  • Systems
    Systems Posts: 14,872
    edited January 2009
    wald0 wrote: »
    Actually there is a very good understanding of their ideology around these parts.
    Yes they are great
    My guess is that many here will disagree with this statement.:)
    I have my popcorn at the ready.:D
    Testing
    Testing
    Testing
  • wald0
    wald0 Posts: 62
    edited January 2009
    GV#27 wrote: »
    Actually there is a very good understanding of their ideology around these parts.My guess is that many here will disagree with this statement.:)
    So some think they aren't great? Spit your brains people. What kind of speaker cables should I buy for my Monitor 10's? Go.
  • Systems
    edited January 2009
    wald0 wrote: »
    Yes I think there will be a few subsequent posts indicating thusly.
    Testing
    Testing
    Testing
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2009
    Search the forum for Monster Cable, you'll find plenty of opinions.
    The most diplomatic thing I can say is you can find better cables cheaper.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited January 2009
    wald0 wrote: »
    I can only relay my own experience with Monster's "fine products".
    I thought I was going to have to return my new amp for repairs, due to it frequently going into protection mode. As a last-ditch effort to avoid repair, I pulled and replaced the Monster IC's with cheapo, throwaways. BINGO.
    No more protection mode. As a result, I have new IC's on order from Monoprice, and have cut up the Monsters. I was amazed how the quality ceased under the jacketing, the insides were pathetic.
    Fantastic marketing though....
  • SEH
    SEH Posts: 91
    edited January 2009
    wald0 wrote: »
    The master pin is a sort of base termination that you can connect their brand of tips (bananas, spades, whatever) to, or use as a pin connector. There are other cable manufacturers that do something similar to this. It allows you to switch the ends without having to tear up the termination and re-solder things. If you know you're always going to use bananas, then just get the regular banana connectors.
    Of course, you won't want Monster now anyway.
  • wald0
    wald0 Posts: 62
    edited January 2009
    SEH wrote: »
    I think it is for people for whom money is no object. I'm sure they are the best granted cost isn't a factor?
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    ~M~ sucks. You can do way better.
    Ben
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    wald0 wrote: »
    No...Monster is the kind of company that relies on consumer blindness basically. They throw a bunch of technical terms and "reasons" for why you need all the features that are in their cables...and they're really overcharging you for something that you don't need.
    I've used several Monster interconnects that I paid around 50 bucks for...and I now use a Blue Jeans Cable interconnect that cost me about 30 bucks...and it blows the Monster's out of the water. Monsters are for audiophiles with to much money that want a brand name.
    You'd be better off going to bluejeans cable or monoprice.
    Also, that Monster connector/adaptor thing isn't even really that great by concept. Just by using a connector you're creating a gap in the signal flow. With these connectors there are two gaps in the signal flow now. Never used them personally, but it doesn't really sound like a good idea by concept unless you're switching connector types frequently. I'd just get some regular banana's..something besides Monster brand. GLS is a pretty highly recommended brand.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • wald0
    wald0 Posts: 62
    edited January 2009
    Looked up both. Monoprice has good prices but they look almost too basic. They look good but is it possible that NONE of the features that Monster advertises are necessary? Might as well use lamp cord. I'm kidding. But I looked at Blue Jeans too the twisted 14-guage look promising. I might check them out.
  • wald0
    wald0 Posts: 62
    edited January 2009
    But seriously though about the Mono's I think they look like some bomb cords, I just think that having some kind of protection from outter noise would be good, even if it might not be a big deal to most ppl. For only a buck a foot and I only need about 20 total, might as well.
  • shack
    shack Posts: 11,154
    edited January 2009
    There are no monster cables in any of my rigs. Never will be. They are a step above the patch cords that the mfgs give you free when you buy a DVD or CD player (but just barely).
    www.signalcable.com or www.audioquest.com.
  • wald0
    wald0 Posts: 62
    edited January 2009
    shack wrote: »
    I'm sure those are better than Monster, but how is that any different? The Audioquest stuff is even more expensive. I don't think I'm gonna spend more for my connects than for my speakers. What's people's thoughts on Blue Jeans and do you only buy them for lack of more money?
    I personally buy them because they are comfortable and they keep my legs warm.
  • gdb
    gdb Posts: 6,012
    edited January 2009
    Check the "for sale" page/thread in the "flea market" section! Great deals from Club Polk members on cables that come (usually) already burned in and with honest reviews from the seller and other users/owners.;)
    http://www.polkaudio.com/forums/showthread.php?t=76257
    http://www.polkaudio.com/forums/showthread.php?p=980822#post980822
    ^^^^^Click these links^^^^^:)
  • shack
    shack Posts: 11,154
    edited January 2009
    wald0 wrote: »
    There are countless threads on this forum discussing the various attributes or lack there of (depending on the poster) of various cables. There is no definative "right" answer or solution. Spend some time using the search function and you will be able to find information about all of the cables mentioned so far in this thead and many, many more.
  • wald0
    wald0 Posts: 62
    edited January 2009
    shack wrote: »
    Right on
  • comfortablycurt
    edited January 2009
    wald0 wrote: »
    It doesn't matter how basic it looks...it's how it performs that matters. Monster Cables have cool looking stylish connectors and things like that, to give you the illusion that it's worth all the money you just wasted on it. Really though...how much time do you spend looking at your connectors? Doesn't really matter how "stylish" they are.
    As a few other people have said...this topic has been discussed to death on here. You should be able to find all of the info you need using the search function. Monster Cable isn't used by anyone who is actually serious about their sound though. They aren't "the best" by any means at all. You can get a much higher quality cable for less money through other companies.
    Monster can be likened to Bose...they advertise and market their products like crazy, and they put a lot of focus on making them aesthetically pleasing. That's the only reason they sell the way they do. Go to any professional radio station or recording studio and look at the cables they're using. They aren't monster cables...just regular old cables like you see at bluejeans or monoprice.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2009
    Monster Cables are fine/ Just overpriced. IMO the most important thing to look for is gauge. It's been my experience that size matters.;)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • wald0
    wald0 Posts: 62
    edited January 2009
    Keiko wrote: »
    Are we talkin' cables or Bowflex? :p
    Poor humor...Carry on.
    That's my style... slip in a joke whenever humanly possible :cool:
  • Motzart
    Motzart Posts: 1,075
    edited January 2009
    AGREE 100%!!
    Keiko wrote: »
    My advice, if you see a Monster, run like hell. Dollar per dollar, there's better cables than Monster. In some cases, less. MonoPrice has a great offering for inexpensive cable. If you want better, go with the AudioQuest, Signal or Blue Jean's offerings that have been mentioned.
    Just a good quote from another forum I was reading when I had the same question.
    Made perfect sense!
    "No reason to buy over priced cables. My rule of thumb is to spend 10% of the purchase price of the object being connected. If your Av receiver cost 500 then 50 dollars worth of speaker wire.
    You will receive hundreds of recomendations for cabling. Keep within YOUR budget. All the testamonials in the world will not make a 150 dollar DVD player produce a picture comparable to a 1000 dollar one by using 200 dollars worth of wire."
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    For at least the first six months I was on this forum I was using monstor cable for speaker wire and interconnects. I bought them dirt cheap at a local high volume liquidator. They were ok, not great but not bad. I've since replaced most of them (the surrounds still run on MC wire). Anyway, point is that I had Monster Cable interconnects on my signature up until maybe 6-8 months ago and not one of the old timers flamed me or teased me or got in my face about it. But then I didn't brag the MC's up either. I just want to say thankyou for not pointing out my ignorance toward these IC's and speaker cables. Almost brings a tear to my eye thinking of how kindly I was treated.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • SEH
    SEH Posts: 91
    edited January 2009
    A gap in the signal flow? I think two pieces of conductive metal with enough surface area in contact should be the same as one solid piece of metal as far as the electrons know.
    The concept behind these modular connectors is not novel.
    http://www.mitcables.com/?option=com_virtuemart&page=shop.browse&category_id=18&Itemid=29
    You wouldn't be saying it's a bad concept just because you associate it with Monster, would you? Because that would be just another form of consumer blindness.
    Wald0, there's nothing special about Monster wire. They don't own their own copper mills or wire pulling factories. They put fancy looking jacketing and connectors on basic wire you could get straight out of any decent electronics catalog for a fraction of the price. What they charge for their product bears no relation to the cost of making it - it is what their marketing research has found people will pay, no more or less. They throw a lot of technobabble around that their marketing department thought up - stuff that you will never find in any industry engineering publication, because it's complete and utter BS. They rely on lots of customer testimonials about the quality of their product, rather than any kind of controlled testing by third parties. In these respects, they're a lot like almost EVERY OTHER audio wire manufacturer.
    But I think their true sin, what really gets them hated, is that they're so damn successful at it. People who know nothing about audio know the brand name Monster thanks to relentless advertising and savvy product placement. They truly are the Bose of cables.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2009
    Fongolio wrote: »
    Naw, we just made jokes about your living in Canada...........:D
    RT1
  • gdb
    gdb Posts: 6,012
    edited January 2009
    Another reason to boycott "M" corp. products is that they are bullies and file lawsuits against anyone and everyone with no merit or basis for doing it! If all else was equal ie. price & quality, I'd still buy from another manufacturer just on moral grounds alone. I do have some "grey market" M interconnects that I got dirt cheap on ebay, they're OK and....my buying them DIDN'T put any money into M's pocket. Click link below to get some idea of what kinda crap M tried to pull on BJCable:eek:
    http://www.bluejeanscable.com/legal/mcp/index.htm
  • suprafantx
    suprafantx Posts: 249
    edited January 2009
    Should I buy Monster cables if I can get them with 75% discount?
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • comfortablycurt
    edited January 2009
    SEH wrote: »
    No...I'm not just saying that because it's Monster brand. I've seen the same style connectors from other retailers...and it still seems like a bad design by concept to me. Even if there is lot of surface area creating the connection, it still isn't going to be as good as one solid piece conducting the signal.
    The only situation I would ever want to buy those, would be if I had to change connector styles all the time...which I don't foresee ever having to do really. I wouldn't buy those from any company personally. To each their own though.
  • Montoya
    Montoya Posts: 506
    edited January 2009
    I bought some M-series monster wires off of the bay and they are in my opinion put together very well and for the price I paid they are very very good. My main rig has all audioquest wire and I don't plan on buying anymore monster products but in my opinion the quality is good the power conditioners are really nice, the amps, and speakers they have. If they are bought gray market they are a good buy but full retail is a rip off. I think if the buisness practices had not been what they are today I would be a customer for some of the items they carry but I hate corporate bullies.
    suprafantx wrote: »
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2009
    Monster is okay if you get it 80% off. I have used and like some of their cables, but never paid retail.
    I think I got some subwoofer cables from them for $3 + $15 shipping (ebay). Actually a very nice, long, thick cable for $18 shipped. Only problem is that it retails for $100 which is what most people end up paying for it at BestBuy. Probably worth something in the middle for most people.
    I like Signalcable.com and Bluejeans.com cables for the price. If you hang around here and Audiogon long enough and know what you're looking for, you can find much better for good prices (MIT, Audioquest, too many others to name).
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • asd1234
    asd1234 Posts: 30
    edited January 2009
    Just go to Home Dept. and get some cables there. It will save you $ and get better quality.
  • ben62670
    edited January 2009
    asd1234 wrote: »
    What their speaker wire that turns green with age? Crap RCA's? If you want to go real cheap with speaker wire WalMart has decent 14ga wire in the Automotive department. Not the stuff in electronics.
    Ben
