Some install pics!
Well as many of you know I've been working on a new system in my 95 Civic Coupe. Are are some pics of the build so far. Let me know what ya think so far guys. Thanks.
Rob
Rob
"My Theater Room"
"My Theater Room"
Post edited by Grimster74 on
0
How are you going to run those amp wires? Send them thru the board or build a cap to go over the amps to hide all the wires.
What kind of subs are you going to run? Just took my 9500's out my truck for the winter so I can take it to work without anyone braking in. Need the 4x4 with all the snow. Trying to debate with subs I'm going to go with this spring.
Very tight man. Looks real sweet. I wish I had carpentry skills like that. If I was to attempt something like that it would look like a 4 year old did it.
XboxLive--->avelanchefan
PSN---->Floppa
http://card.mygamercard.net/avelanchefan.png
"My Theater Room"
"My Theater Room"
In a car trunk, it usually sounds better if the subs are facing towards the rear of the car.
Rob
"My Theater Room"
Probably the only thing I wouldve done different is
1. Change the color of the carpet where the subs are mounted to black, and keep your outside plate gray. But thats personal preference.
2. Use the same piece of carpet for all 3 pieces on the front. Just lay all 3 pieces together, carpet them, then when youre putting it in the vehicle, you can fold them in to get it in the trunk, then unfold them back to flush when you're done. Makes for a seamless install.
It really does look great though, hopefully it sounds as good as it looks!
-Cody
1. I actually had planned on painting that area white and high glossing it but it was just to damn cold outside. Who knows, once it warms up I may still do it.
2. Weather provided, I should be redoing the trunk soon. I want to redo the outer peice that way I can install a press on grill to hid the subs and/or make a whole new grill out of the 3/4" MDF that mounts on the outer peice of the subs that way the subs that sit flush with the outside peice have atleast 3/4" clearence so the subs won't be touching the grill cloth. If this makes any since what so ever, what would you suggest?
Oh, it does!!!
"My Theater Room"
Will do, just let me know when.:D
"My Theater Room"
"My Theater Room"
Center - LSiC
Surround - pair of TL3's
Amplification - Parasound 2125
AVR - Onkyo 706
CD/SACD - Onkyo DV-SP506
SUB - MartinLogan Abyss
55" Panasonic Viera TC-P55GT30 3D
Bluray - DMP-BDT310 Panasonic
Its a 99 Conv. with a 302 stroker modular motor, with a 76mm turbo and a tko behind it.
Nice build.
This question may be pointless due to the fact that the thread was started over a year ago but here goes. I'm currently building something very similar in my hatch. Just curious, what material is the grill made of?
very sweet
Cool installation. Nice pic!
Speakers:
Fronts: Polk Audio Monitor 70s (x2)
Rears: Polk Audio Monitor 50 (x2)
Center: Polk Audio Monitor 70
KLH Sub GFX-550
