Need SurroundBar Sub Recommendations
Newbie here and a big fan of Polk Audio!
I’ve been looking at different soundbars from various manufactures and have chosen the original Surroundbar 42” as a match for our 46” LCD. It’s a match within an 1/8th inch in width of the screen not to mention a big improvement over the TV’s speakers.
Lucky me found this open box in pristine condition yesterday priced so well that I couldn’t pass up the deal.
Here’s my problem: Is there a wireless sub that will compliment the Surroundbar or a good wireless Tx/Rx so I can use a Polk sub?????
Here’s the room. 15’ x 29’, we set about 10’ from the TV. The AV equipment is behind the doors on the left side. It's a difficult wall but I’d use a drill and drywall tools and wire one but I’d meet serious opposition from the Mrs. this time.
Any help is appreciated.
Post edited by ReWired on
We don't have a wireless sub just yet but if you can wait just a bit the PSWi225 will be available in a few months (we're expecting March) and is the perfect match and solution to your issue
-Eric
-Polk Audio -
Eric
Any chance of getting specs before the release?
Thanks for the heads up!
Greg -
You mean like power and dimensions etc? I could check some prototypes here. They *should* be close to the final production.-Eric
-Polk Audio -
If you could that would be great.
It will be floor firing- 13" Hx 12.5" W x 12.5" D.
100 watt power.
2.4 GHz wireless transmitter.-Eric
-Polk Audio -
It would be good to know the frequency response when its available.
Thanks again! -
Thanks again!
and pricing information would also be appreciated. -
This will answer some of the questions;
http://www.polkaudio.com/downloads/product-sheets/PSWi225.pdf -
am looking for this sub ..... why is it not on the polk site?
Eric;
* Great little video on the product but it cuts every once in a while... You might want to get marketting to fix this.
* When will the specs be available (when you click on specs it leads you to the PSW series).
* I am also concerned/looking for the weight since I would like to use such sub in a portable system.
* Another concern, is the Tx/Rx frequency selectable (in order to switch to a different channel if someone near by uses same frequency as you probably know it wouldn't work, be confused if the case arised).
* Of course I sure would like to get some MSRP on the product!
* Wiil the Tx also be available seperately???
Cheers!
TKDARE TO SOAR:
