Yup, another newb speaker wire question
Docsab
Docsab Posts: 2
So I recently refinished the basement, and intending to set up a home theater area, wired the walls with 14 AWG previous to drywalling/finishing. Now I am ready to set up my system(Onkyo 606 and Polk RM6880) but because of some unforseen issues, I need to move the location of the receiver from where I had previously anticipated.
So a couple speaker wire runs are now short. They are drywalled in and would be hard/impossible to rerun in their current location. Would it be a poor idea to splice an extra length of wire to the end? Would I loose fidelity with a splice, say a couple wire nuts, to add an extra few feet to the run or would I be violating some basic audiophile commandment that I should have known about since the third grade?:confused: Thanks for your comments!
Post edited by Docsab on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited January 2009
    Depends on you level of analness. I'd solder & shrink wrap, though.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Solder the joints with good solder, and heat shrink them;)
    Welcome to Club Polk.
    Ben
    Ben
  • ben62670
    edited January 2009
    TNRabbit wrote: »
    That's a quick rabbit:D
    Ben
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    WOuld solder using silver solder or something else ?
  • Willow
    Willow Posts: 11,325
    edited January 2009
    Silver would be a great choice
  • jeeper_nick
    jeeper_nick Posts: 27
    edited January 2009
    Absolutely silver for condutivity purposes. If it were me, I might consider putting the "patched" area in a junction box to keep it away from insulation, etc. In essence you are creating a weak link in the chain and if something is going to fail/overload/short, it will most likely be where the solder/heatwrap job is. Better to be safe with a $.79 single-gang junction box than an in-wall fire. I'm a big better-safe-than-sorry sort of guy, though.
    thsmith wrote: »
    Coming Soon: The GregorPlex II Cinema
    Sanyo PLV-Z2000 Projector
    106" HDTV Formatted Electric-drop screen
    50" Samsung PN50A450
    Onkyo TX-SR876
    Emotiva UPA-7 Amplifier
    PlayStation3
    Monster HTS 3600 mkII
    *undetermined upconvert DVD player*
    Polk LC265i Fronts
    Polk LCiC Front Center
    Polk LC80i Rears
  • Docsab
    Docsab Posts: 2
    edited January 2009
    Wow, thanks for all the quick responses! I'm feeling better about not having to redo the run. The patched area will be outside the wall- actually just adding a few feet in an unfinished storage closet, so it should be cool.
    One other question though, I was reading Crutchfields guide to installation and they stated the three front speakers should all have the same length speaker wire, as well as the surround speaker wires should equal each other in length, to assure the signal reaches each speaker at the same time. This surprised me, as I wouldn't think a difference of 5 or even 10 feet would matter, given the speed of the signal. Agree? Disagree? Thanks again:)
  • AudioGenics
    AudioGenics Posts: 2,567
    edited January 2009
    suggest staggered (non-adjacent) westinghouse wire splice technique , solder , then shrink wrap .
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2009
    Docsab wrote: »
    Not suggesting that it needs to be done, but if you were to do it, I guess using the old wire to pull the new wire though won't work for you? Was the wire secured anywhere behind the wall?
    This is one of those times when your kicking yourself for not thinking of running the wire in conduit huh? ;)
    Not familiar with the Onk 606, but if it has an AutoEQ (where you use a mic to calibrate), it should account for any delays. If it doesn't you should at least be able to manually adjust the delays if something doesn't sound right.
    ____________________
    Pool: Atrium 60's/45's
  • WilliamM2
    WilliamM2 Posts: 4,810
    edited January 2009
    Docsab wrote: »
    It's nonsense. There won't be any delays unless the differences in length are a mile or more.
  • dkwrrt
    dkwrrt Posts: 7
    edited January 2009
    Hello all,
    i am fairly new to this arena and would like to know a couple of things. Firts off i just got montour 50's for my fronts and a cs1 center yesterday to replace a 16 year old bose cube speaker system, now i just read an article by roger russell about speaker wire and if i read it right i could use good 16 guage lamp cord and get the same results as buying "monster cables". So is that right and if so will it hurt my onkyo 705 receiver. Gee that is a mouth full, and should i biwire my fronts? Thanks for any help!
  • gdb
    gdb Posts: 6,012
    edited January 2009
    Just a little trick.... groove the drywall within 3" of the floor,and run a new length wherever you want. The base molding will cover it up, just DON"T NAIL THROUGH the wire ! No more need to splice/solder;)
    F1nut Posts: 52,244
    edited January 2009
    Forget you ever read that crap.
  • dkwrrt
    dkwrrt Posts: 7
    edited January 2009
    F1nut, thanks for the reply but are you saying to buy as good as you can afford on the wire. And do you think I should biwire my front speakers. Thanks for all your help.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2009
    The Truth about Speaker Wire
    Despite the effectiveness of Gordon's cable demonstration and the truth about speaker wire, people visiting the McIntosh room at the shows, who had not experienced the cable demonstration, were disturbed that we were using ordinary heavy zip cord instead of one of the popular brands of speaker wire. Instead of listening to the McIntosh speakers and electronics, they recalled "bad" things they had been told about "common" speaker wire and this promoted questions about the "inferior" wire being used. When we changed the wire to a popular brand of wire, customers were happy with the setup, and directed their attention to the McIntosh equipment.
    The demand for high quality speaker wire was increasing and appeared to be a new marketing area for several companies. McIntosh did not make or sell speaker wire. The solution seemed very obvious--rather than spend time and effort to create negative sales for McIntosh dealers who were beginning to sell speaker wire, it seemed best to encourage the speaker owner/customer to consult with the dealer about what speaker wire to use. Consequently, I no longer recommended the kind of wire or wire sizes in the speaker manuals.
    By 1988, McIntosh no longer supplied audio interconnects with the electronics. Again, many kinds of special audio cables were available to the customer/owner. The dealer could also be consulted about what cables to use.
    I credit the success of the speaker wire industry to their expert sales and marketing ability. However, it is my experience that ordinary copper wire, as long as it's heavy enough, is just as good as name brands.
    Looking at this from a different perspective, there will always be those who will want expensive wire, not because there is an audible difference, but because they may value pride of ownership and prestige in a similar way to that of owning a Tiffany lamp or a Rolex watch. BY Roger Russell
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2009
    If you play around with this hobby enough your ears will hear the difference and you'll realize that the Roger Russel stuff is ****.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
    F1nut Posts: 52,244
    edited January 2009
    dkwrrt, I would suggest you buy wire that fits the level of your system. A general guide line would be to spend about 10% of the total value of your gear on wire. I would also suggest to stay away from the M brand.
    Personally, I haven't found a benefit to bi-wiring, but you should try it for yourself as that's the only way to know for sure.
  • Knucklehead
    edited January 2009
    if it works and your happy....use it, who cares what anybody else thinks
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
